GSR Swap help 94 del sol
First time doing any engine swap so I'll start with what ive done then where I am and what I want to learn to make this all correct.
Had a D15 in my del sol before swap took the pos and threw in my B18c1. I had a parts car I was getting some parts off of since the block was blown and the "parts" car was I believe OBD1 and the motor I bought to put in my car was again I believe was OBD2. so the parts car I got had wiring harness and OBD1 ecu so I decided to swap my OBD2 engine to OBD1 since the parts I had were that and my car was already OBD1 (Don't know if my car being OBD1 mattered)
So now my B18 is in and mounts are looking good.
Problem 1. I don't know where the positive cable to the battery was wired on the parts car since I took it all off. on my D15 its in the wiring harness but on my parts car harness it's not on the harness.... I cant even find my positive cable. suggestions and pics please.
Problem 2. My throttle cable I cant find out how to run this wire. I only have the stock one from my D15 but it seems a bit long but it does have a bracket that's attached to the driver side wheal well.
Problem 3. I have a cable from my wiring harness that doesn't have a plug in on the driver side. I also have one that would fit it on the passenger side. There are a few plug ins (male and female) that all fit these connections so my question is, if the male plug in is same in 2 areas does it matter what wire plugs into that female plug?
Please understand this is my first big project, I did this 90% to learn so if my question is simple or stupid take that into consideration.
Ill make a forum after its complete of all the pictures I've taken. once the motor is done and running I have plans for the rest of the car.
Re: GSR Swap help 94 del sol
Pic fail.
Typical pos cable will go to starter and fusebox.
Throttle cable too long is not a problem....... Too short would be a problem.
Harness plug ,,, you may need to split the harness apart in order to move plug(s) from one side to the other to match up with the car. I did ONE swap several years ago (Integra motor into a 5th gen Civic) and had to do this, and from there it was plug and play (thank god LOL)
Pic fail.
Thanks for the help, that helps a lot. So if there is 2 male plugs that can fit in a female it doesn't matter which one I plug into it? If that's the case I might be able to move some the plugs around. The harness came off of another del sol like mine but the engine was I believe from a older gsr.
I might need to go to a junk yard for the positive cable and if the throttle being to long isn't an issue then I'm no to worried about those 2 issues thank you.
Pic fail.
*edit* just took a look at it and I think the plug in on the passenger side goes to the o2 sensor on the exhaust. Does the wiring harness plug into the o2 sensor or does it plug into the engine?
Two identical.looking plugs all have different wires, you gotta get wire diagrams and verify what you have and wire colors match components before plugging it in.
Got pics of the plugs in question?
I used this url for most of my information and from what it said is how I determined my parts motor was obd1 and my new motor was obd2. so if im correct would I need a diagram for obd1 wiring harness diagram?
http://honda-tech.com/hybrid-engine-...-swap-2976738/
hope my pictures load this time
I found this one Ill have to check the wires and see if the harness is the same tho but this one says its obd1
http://teamsolcal.com/forum/thread-19884.html
any key words I should use to find a diagram
I remember having to split the original engine harness open to relocate the O2 sensor plug to line up with the Integra sensor location during my swap too.
Some of the cars you can get TPS and MAP connectors swapped and it won't run worth a damn LOL. IDK if that's possible on yours but I've seen it more than once.
Sounds good, ill see about a manual when auto zone opens its almost 6am and I haven't gone to bed yet xD Ill update my post later if I run into a problem or figure it out.
I just realized I might be confusing parts of different jobs.....I've only seen like 40,000 cars since I did that Integra engine swap.
Ill just make it easy, I can post a video how to do a engine swap into a EG/Delsol with a B Series motor, simple and easy... I can pull a dseries with a buddie out within 30 minutes, and pop a D within two hours... So why not, done a ton of these swaps...
Joethornton
Aug 7, 2015 09:53 AM
