Engine Performance Modifications Post information/questions about Forced Induction methods (Turbos & Nitrous Oxide) and swaps here
Engine swap easy yes or no
Old Sep 6, 2010
brandonb0013's Avatar
brandonb0013 is an unknown quantity at this point
i have a 93 civic LX with a 1.5L 16 valve engine. all i want to know is is it possible to put a 1.6L VTEC from a 95 civic in the car without major changes? i removed the engine today, i need a new engine and can get the VTEC cheap. are the two engines the same CID? (cubic inches displacement) is the intake the same? etc etc
Old Sep 7, 2010
02civicsi02's Avatar
Low and slow!
Re: Engine swap easy yes or no
This should be a easy swap to do. The stock mounts should work but you will need the wire harness for the d16 vtec and the ecu. Think thats all you need and which one are you going to get the d16y8 or d16z6.
cloudguy
Apr 28, 2015 05:02 AM
shawe90
Apr 14, 2015 07:10 PM
Cross
Jan 6, 2002 01:31 AM
robbclark1
Dec 12, 2001 12:18 PM
supercivic01
South
Nov 30, 2001 11:27 AM
