Engine Performance Modifications Post information/questions about Forced Induction methods (Turbos & Nitrous Oxide) and swaps here
Turbo or Swap?
Old Feb 1, 2011
RedEX95's Avatar
RedEX95 is an unknown quantity at this point
Turbo or Swap?
I currently have a d16 and i am either going to turbo it, or swap in a b18. I would not turbo the b18 which one do you guys think i should doo??
Old Feb 3, 2011
burrsg101's Avatar
burrsg101 is an unknown quantity at this point
Re: Turbo or Swap?
A properly turboed d16 would be responsive and produce more power than the b18c and way more than an ls b18, and be MUCH cheaper than the b18c swap, plus easier to do, and more fuel efficient. It all depends on what you want. If your going for making it as simple as possible and willing to sacrifice a little power go b18c, otherwise turbo the d16. This is all assuming your d16 is in good condition and up to date on maintenance. If swapping the b18c your looking at over 3k to swap it, the ls b18 is much cheaper but also only a 5 hp upgrade from your d series and not much more torque, but a considerable loss in gas mileage and lower redline. I had an ls swapped crx, it wasn't slow but wasn't really fast either, I just rode in a turbo d15 mini me in an eg hatch that pulled good from below 3k rpm and still hit over 200whp and that was pretty quick,and I haven't had the pleasure of riding in anything with the b18c but looking at hp I'd assume itd be a hair slower than the turbo d15 if swapped in an eg civic. Hope this helps!
runawaykinms
15
Mar 22, 2019 10:32 AM
Jaryn
May 17, 2016 02:52 AM
Rodrigo Pizarro
Forced Induction
Sep 6, 2015 03:48 AM
DatGuy_Robb
Sep 3, 2015 08:08 AM
justcruzin125
Aug 11, 2015 09:09 PM
