Engine Performance Modifications Post information/questions about Forced Induction methods (Turbos & Nitrous Oxide) and swaps here
Noobie Mech needing HELP with swap.
Old Aug 27, 2010
garrettj's Avatar
garrettj is an unknown quantity at this point
Exclamation Noobie Mech needing HELP with swap.
I have a stock 1992 Civic dx. It has a d15b7 with an auto tranny. I am going to swap it with a d15b vtec-e engine I stole for 500 bucks, it has a 5 speed on it though. Here are a few questions: Do I need a different wiring harness/cluster? Do I need to get different axles? Do I need both motor and tranny mounts replaced? What kind of ECU do I need and does that need different wires? I have never done a swap, so any advice would be helpful.
Old Dec 26, 2010
xXHellxRaiserXx's Avatar
xXHellxRaiserXx is an unknown quantity at this point
Re: Noobie Mech needing HELP with swap.
if the new motor is same year/ obd all you should need is the new ecu for that motor and i think the motor mounts will work you will probably need new axles and a shift linkage depending on what car the new motor came out of
Old Dec 30, 2010
StaticFire450's Avatar
Bringer Des Blutes
StaticFire450 is an unknown quantity at this point
It is a D15 block so the motor mounts are the same. The tranny mount may need a different style, going from Auto to Manual(Not sure though). As For the Axles... Most likley, I didnt notice a difference in mine, compared to my GF's. Then again, By the time I was putting them back on, I was in a hurry.
If you dont get the wiring harness for under the hood, You may need a wiring cluster for the Vtec Distributor. Rather than that, I couldnt think of anything really. Their the same engine, just one has Vtec-e.
mattdoc
Mar 14, 2017 12:10 PM
em2_k20a
May 19, 2015 03:36 AM
Myredjonda
Apr 14, 2015 07:00 PM
RickyRocket
Nov 30, 2001 10:14 AM
