Engine Performance Modifications Post information/questions about Forced Induction methods (Turbos & Nitrous Oxide) and swaps here
95 civic sedan vtec swap
Old Oct 21, 2011
rmdt4's Avatar
rmdt4 is an unknown quantity at this point
I have a 1995 honda civic dx sedan, and im looking for a vtec engine to replace with my current engine. What are the kinds of vtec engines that fit my current engine mounts? If there isnt any, what do i have to do to fit other vtec motors in my car?
Also, if i wanted to step up to a B series engine, which engine can i use and what will i have to do to install that?
My current engine should be a d15b7.
Old Nov 15, 2011
ottmitch's Avatar
ottmitch is an unknown quantity at this point
Re: 95 civic sedan vtec swap
im pretty sure you can just get a d series v tec head. i think it just bolts on ... and then you need the v tec ecu ? and i THINK the v tech dizzy. but ! im new to all this honda stuff so hopfully somone with more experiance will step in and correct me if im wrong before to long.
Old Dec 21, 2011
egkid1's Avatar
egkid1 is an unknown quantity at this point
u also could just get the whole vtec ecu. a z6 or y8 head will fit right on. and until u get the ecu changed will just run like normal with a bit more power due to the bigger ports on the head. after the vtec ecu is installed there u go. u also have 2 have a pressure activated switch for the vtec. any d series with the exception of a zc motor will fit right in to ur car. a b series mounts r different. i fabed my own on my buddys car wasnt that hard. but ive been doing this for my whole life with chevys so xD. the tranny will need different mounts also if memory serves and, the linkage with ur trans will need to b changed
Old Jan 25, 2012
Procomper93's Avatar
Procomper93 is an unknown quantity at this point
I also have the same motor but my civic is a coupe i wanna know what i could do for the v tech swap as well my car needs a new engine anyways
vtec92
May 4, 2017 03:20 AM
usajags84
May 10, 2015 08:11 AM
aus10
Apr 13, 2015 09:26 PM
Lightman
Nov 10, 2001 06:44 PM
Crash2002
Oct 26, 2001 05:02 PM
