Engine Performance Modifications Post information/questions about Forced Induction methods (Turbos & Nitrous Oxide) and swaps here
this is what i am looking at so far, help
Old Jun 14, 2011
lt93civic's Avatar
lt93civic is an unknown quantity at this point
i have a 1993 honda civic EX coupe, engine swap went bad (long story)
i am going to be purchasing a JDM d16zc sohc vtec, (its the only series i want atm so please don't just say i should get a k20 or h22 or a b series)
this is the list of parts i have come up with so far for the build.
-Eagle H-Beam Rods Honda
-ferrea competition plus valves
-supertech bronze valve guides
-supertech valve seals
-ARP headstuds
-gates racing kevlar timing belt
-ACL Race Main Bearings
-wiseco forged pistons.
-Hondata S300 Engine Management
-edelbrock victor x turbo kit
-that comes with-
-Garrett ball bearing Turbo preassembled with exhaust manifold and elbow, including coolant and oil lines(GT28RS turbo)
-Edelbrock high performance manifold
-Preassembled Russell oil lines with adapters
-TiAL blow-off valve
-Bar & plate intercooler with TIG welded cast aluminum end tanks
-Ceramic coated Turbo piping and high flow air filter
-All gaskets, adapters and instructions
-O-ring sealed compressor inlet/outlet pipe flanges
-Level 2.4, Z6 Turbo Street/Race billet, vtec(camshaft)bisimoto's site
-D16Z6 Spring and titanium retainer kit Bisimoto's site
-2MS, '92-95 civic clutch bisimoto's site
-GReddy Spectrum Elite SE Exhaust System
-Zex Nitrous 82021 - ZEX EFI Nitrous Systems
-or Edelbrock Direct Port Wet Nitrous Kits
(would like opinions on which nitrous kit would be better)
-DENSO Iridium Power Spark Plugs 2 steps colder
-Koyo High Performance Radiator
-GReddy PRofec B-Spec II Boost Controller
-Edelbrock Pro-Flow Secondary Fuel Rails
-Blox Throttle Body 76mm
(i know i need a 020" overbore, port and polish, and some notching for the eagle rods(my friends machine shop will be doing all that) i want to sleeve the block as well, for safety)
i also know i need to get some kind of suspension system and racing axle's but im not sure where to find those at....
thats what i have so far. i know its alot of money but its not like ill be buying everything at once, it'll take me about 6 to get it all.
if you think something is overkill or that there is a better part out there let me know. all help is greatly appreciated. this is my first honda and i want her fast.
thanks!!
and if you think it looks good could you tell me so i know im on the right track.
Old Jun 15, 2011
lt93civic's Avatar
Re: this is what i am looking at so far, help
nothin?
