Engine Performance Modifications Post information/questions about Forced Induction methods (Turbos & Nitrous Oxide) and swaps here
New member here, a have a few questions
Old Jan 21, 2010
BrianCivicDX's Avatar
BrianCivicDX is an unknown quantity at this point
Hey guys, first off my name is Brian and im 27 from Easton PA... Anyway I have a 1995 Civic DX. I just had an engine swap yesterday and it is a 1996 JDM D15B Non vtech motor. I can not for the life of me find out what the Engine power is for this motor. It is a bit faster then my old engine. I am positive this is a non vtec. I also own a 400 whp Mazdaspeed3 with a Gt3076 turbo.
anyway my ?'s are...
1. What is my engine power output?
2. What is the tq spec for the Valve cover Bolts?
3. With my Old engine and new engine my Idle bounces up and down and its pissing me off cause i don't know why. Is it a sensor on the IM?
4. How do i replace the bulbs behind my temperature control buttons?
5. Is anyone selling any headers for cheap?
Old Jan 21, 2010
FGsmasher's Avatar
FGsmasher has a spectacular aura aboutFGsmasher has a spectacular aura aboutFGsmasher has a spectacular aura about
Re: New member here, a have a few questions
1. Probably around 130 bhp, but that's not to the wheels of course.
2. Probably somewhere around 84-106 in/lbs. Get a haynes manual, most all D series are the same.
3. It could be a number of things. Does it stop once the car is fully warmed up? It could be a vacuum leak.
4. Haynes manual
5. Ebay, craigslist, etc etc. We also don't know what you consider cheap. BTW, you only have one header.
Old Jan 21, 2010
The bouncy idle starts once the car is fully warmed up. It does not do it when it is cold
Old Jan 22, 2010
95-civic_ex's Avatar
95-civic_ex is an unknown quantity at this point
hey man my car was doin the same thing. it is the sensor on the back of the intake
Old Jan 22, 2010
FGsmasher's Avatar
It could be a vacuum leak if it bounces like that until warm, or your IAC could be dirty and might only need to be cleaned, or the IAC could have taken a ****, or came unplugged.
Where the injectors go into the IM is a common place for vacuum leaks. Start the car, let it warm up so the idle is "normal", then put your fingers around the cushion rings where the injectors meet the IM. You'll hear a rushing wind/air noise if there is a leak there. Also, check around all the connections of your intake system (Intake pipe to TB, TB to IM, etc etc)
You could also get soapy water and spray it and hope you see bubbles.
Old Jan 22, 2010
The car idles fine untill it is fully hot. once fully hot the idle starts to bounce.
Old Jan 22, 2010
do u know what sensor exactly cause there are like 3 sensors on the back of the Intake manifold
honda200192
Suspension
Oct 27, 2019 12:23 PM
amrhamed
Jun 1, 2015 08:08 AM
viper775
Dec 9, 2001 10:52 PM
