Engine Performance Modifications Post information/questions about Forced Induction methods (Turbos & Nitrous Oxide) and swaps here
B18A1 1994 civic
Old May 23, 2018
B18a1's Avatar
B18a1 is an unknown quantity at this point
B18A1 1994 civic
I have a bare block and bare head I want about 300 to 350hp. I know I'm going turbo but what else should I beef up while the motor is nothing right now. I was thinking forged pistons 9.0:1 ratio. I don't think that's to high for turbo. I'm doing forged rods Brian Crower 403 cam shafts, valve springs, retainers, etc... but I hear people say to get a port and polish. Just not really sure where to send it out to get done. I live in northeast Ohio not alot of tuner garages. Also from what I been researching I'll need to upgrade my fuel system. I have an idea of the direction I'm going. If anyone could help me out on something I'm missing or if this setup is pointless. It would be much appreciated.
Old May 23, 2018
Wankenstein's Avatar
Re: B18A1 1994 civic
First, if you haven't already, beef up the suspension and wheels first. Power is nothing if you can't keep the car planted to take advantage of it (power). Lower the car on a quality set of coil-overs. Use rims that can accommodate wide tires such as 205/50/r15.
Old May 23, 2018
mac25's Avatar
Dr Krieger of Modification
You can port and polish it yourself. It's easy but can take a long time depending on the quality you want. I got board after a few hours and only really polished the 75% or the ports. But I increased my port diameter by 1/4inch to match the header/turbo manifold.
Some things people forget about other than the main turbo setup, are...
-cooler spark plugs
-fuel pump upgrade
-wide band air fuel sensor
Old May 24, 2018
B18a1's Avatar
-cooler spark plugs
-fuel pump upgrade
Thank you for the input I wanted to do nonturbo high compression setup but everyone said 300hp was out of the question with a B18 non turbo.
Monty022581
Aug 31, 2015 08:32 AM
steve_gicas
Dec 7, 2009 11:41 PM
speedcreations
Feb 27, 2004 11:08 AM
Bulletboy
Oct 19, 2002 02:22 PM
