Engine Performance Modifications Post information/questions about Forced Induction methods (Turbos & Nitrous Oxide) and swaps here
how direct of a swap would this be in a 95 ex sedan?
Old Jan 20, 2012
henry9419's Avatar
henry9419 is an unknown quantity at this point
http://www.bestofjdm.com/COMPLETE-PA...jdmhonda19.htm
how directly would this swap into my 95 ex sedan? and how much more would i have to add to that besides whats included with that? i know its obd2 and my cars obd1, but since an ecu and all is included, i would think it shouldnt matter
before i save for that i wanna do suspension and brakes, and also gotta finish paying off my dad so this wont come for quite a while, but i need something to look foward to
i just realized that ill also need a new console, pedals, and a wiring harness, i dont think im missing anything else but let me know if i am
Old Feb 17, 2012
94-eg rocket's Avatar
94-eg rocket is an unknown quantity at this point
Re: how direct of a swap would this be in a 95 ex sedan?
im not sure about swapping from obd 1-2 ... im pretty sure that u have to rewire your vehicle harness a little and ull need to run at least 2 new wires to the computer for the vtec solenoid the easyest swap is gonna b a b18 b1 out of a 94-95 integra ls. ull need the integra mounts and shift linkage and the wiring will plug right in as long as you get the entire vehicle harness. youll also need to turn the exhaust flange about 20 degrees and leingthen it by an inch but its a pretty straight swap ... oh you need the integra axles too and but the b18 c is a better motor if ur gonna stay naturally aspirated, however if your planning for turbo , get a b1 and a high lift low duration cam and heavier valve springs and youll fly past the type r motor
Old Feb 17, 2012
itzsleepy's Avatar
itzsleepy is an unknown quantity at this point
It spent over 6k putting a b16 in my 95 ex. when u doing a swap, its only smart to buy all new parts. Timing belt, water pump, clutch, flywheel, gaskets, etc... You already have the motor out and its a lot easier to do all this work while its out. So account for all the stuff you need. The motor mounts you can get a kit from hasport or you can use the two side mounts for that motor and get a 99/00 si Rear mount. Shift linkage, you can the hasport shift linkage. Going from obd1 to obd 2 is just not worth all that work. Also, I believe if you was going to use any tuning software, obd 1 was the route to go. I know when I did my swap, Hondata only worked with obd1 ecu. This is why many companies like skunk 2 have obd2 to obd1 conversion harnesses. axles would work from 99/00 si. Pretty much any parts that you would need would be from a 99/00 si for mounting the motor. Other than parts and time, if this motor will fit direcly in, yes. No major modifications are needed. Enjoy, I know i enjoyed my b16 in my eg coupe.
7thgensurvivor
38
Aug 29, 2015 11:50 AM
WaryDriver
23
Jul 22, 2015 07:18 PM
begogadashi
Jun 11, 2015 04:04 AM
usajags84
May 10, 2015 08:11 AM
BREADFAN
Apr 15, 2015 08:58 AM
