Engine Performance Modifications Post information/questions about Forced Induction methods (Turbos & Nitrous Oxide) and swaps here
Need help please
Old Sep 16, 2020
Jeremy Rigsby's Avatar
Jeremy Rigsby is an unknown quantity at this point
Need help please
ok so i have done a complete motor rebuild of an 89 crx si, with the block being a d16a6 and i replaced the head with the 98 y8 head and a p28 ecu. Everything I needed to do the bead swap i got and put on. Car won't start! Can someone please help me with figuring out what I need to do? Can someone send me an actual picture diagram needed for the timing on my set up and all that good stuff please? There's alot of bonch around on the enternet.
Old Sep 18, 2020
mac25's Avatar
Dr Krieger of Modification
Re: Need help please
It turns over though right?
As long as all sensors match the ecu, you chose it should work. (TPS, cam signal, crank signal, map/maf sensor)
Hold the throttle open when you try to start it. If that doesn't work, adjust the distributor.
Also check fuel, spark, and injector pulse.
Old Sep 18, 2020
mac25's Avatar
Ps, make sure you didn't forget any grounds, like the ground to the head.
