Engine Performance Modifications Post information/questions about Forced Induction methods (Turbos & Nitrous Oxide) and swaps here
h22a eg civic will not start
Old Jun 3, 2017
Matt Lankow's Avatar
Matt Lankow is an unknown quantity at this point
im running out of ideas. thanks to anyone reading this and offering suggestions. i have a 92 civic with an obd2 h22a euro type r set up with a s300 chipped p28 ecu and harness built by swapshopracing. i have spark compression and fuel but it still wont start. i just replaced my ignition coil in my dizzy thinking it may have an intermittent spark. but i still got nothing out of it trying to start it. only dtc displayed is ks23 for the knock sensor but it has a brand new knock sensor and i traced the wire from the sensor to the car harness coupling then to the ecu and the circuit was fine. any suggestions would be great.
Old Jun 7, 2017
mac25's Avatar
Dr Krieger of Modification
Re: h22a eg civic will not start
Spark is white/blue right, not red/yellow, right?
How did you check fuel/was it just to the rail, or did your check for ignition pulse as well?
You haven't changed anything in the past three months right, mods/tune up/oem parts?
Old Jun 15, 2017
spark is white and i know i have fuel because it sprays out of the cylinder when im testing spark. also i haven't done any new mods but it has not previously run. this is a new swap and i am trying to get it to run for the first time in the car.
Old Jun 19, 2017
BUMP i am using a jdm h22a that is obd2 in my 92 civic with a chipped p28 ecu (obd1) do i need a resistor box?
