Engine Performance Modifications Post information/questions about Forced Induction methods (Turbos & Nitrous Oxide) and swaps here
1994(not 1990) Vtech problem Please Help
Old Jan 6, 2010
troymrtn's Avatar
troymrtn is an unknown quantity at this point
I just changed the engine in a 1994 civic with a vtech engine. The new engine had 55000 miles so we changed the water pump, timing belt, tentioner, and clutch before installing it. The motor is in and runs great till the abs pump turns on. When the abs pump turns on the engine dies. We didn't work on the brake system and the brakes were working properly before the engine swap. Any suggestions as to what may be going on?
Old Jan 12, 2010
boostnm3's Avatar
boostnm3 is an unknown quantity at this point
Re: 1994(not 1990) Vtech problem Please Help
Are you sure you got all the connectors in the right place? I know you said you didnt work on the abs system, but to me it sounds as though something is plugged up backwards. Also does the computer match the engine?
usajags84
May 10, 2015 08:11 AM
lildoo
May 9, 2015 09:44 AM
vtechcivic
Apr 21, 2015 07:11 PM
jackoncruzpr
Apr 16, 2015 12:29 PM
TaiChi
Dec 17, 2001 09:09 PM
