PDA
View Full Version : Wheels, Tires & Brakes Modifications
  1. How big can i go?
  2. Civic 1,4Si 1997,is that the Original rims and wheels ?
  3. Brake Help
  4. Rims for a 1997 Honda Civic [solved]
  5. 1997 Honda Civic Hatchback (EK) BIG brake kit for 17's (205/40R17)
  6. Looking for Scarebird Rear Disc Brackets
  7. Help please
  8. Max tire size on LX
  9. Wheel size
  10. Wheel offset question
  11. Wheel fitment for Civic
  12. ex and lx drum brake parts
  13. deep dish/stance
  14. Help with Civic Lx wheels
  15. Raise throttle pedal for Heel&Toe
  16. Factory 14 inch wheels replace with factory 15s?
  17. Which 15" tire is the best for 15x7?
  18. Steel wheels with 1 mm different ET
  19. Will Konig zr wheels fit?
  20. 15 x 7.5 Wheels
  21. Need help
  22. Brake Proportioning Valve Routing
  23. Offset (98 civic)
  24. Brake Upgrade
  25. Tire and Wheel take-off swaps/sale?
  26. 97 honda civic ex drum to disc swap
  27. drum to disk
  28. XXR 527 Rims
  29. Need original wheel hub specs for 1999 honda civic lx
  30. Rolling fenders.
  31. Changing wheel and tires.
  32. Finding a correct lug nut socket
  33. 2000 ex rear disc swap
  34. wheel alignment 1997 honda civic si
  35. Tires
  36. Pedal Fades at Stop
  37. Help with rear brakea
  38. 99 Honda Civic DX not starting. Pls HELP!
  39. Best Wheel Size For Flush Look
  40. new member, old civic low miles looking for wheel opinions
  41. Front brake pad grinding?
  42. 16x8 Offset PLEASE HELP!!
  43. Wheel bearing question
  44. Will these tires fit?
  45. Rear drum brake question
  46. Non Genuine Honda Dot 3 brake fluid ok?
  47. Honda em1 best off set ??
  48. 17" Rims on a 97 Civic EX?
  49. 97 Honda Civic DX Brakes go to floor
  50. Grinding Sound When Braking
  51. trade heigth for width? 00 EX
  52. Wheel spacers
  53. Tires and wheels
  54. Quick Question
  55. Wheel fitment
  56. Confirm brake line size
  57. lowering 99 civic and have rim and tire size
  58. Need Help Identifying Wheels
  59. 98 ex coupe on 16x9s (pics inside)
  60. 215/50-16
  61. What tires would fit my wheels best?
  62. 98 rear drums to disc question
  63. 98 civic HX brakes/suspension inquiry
  64. Was given 17s for free will they rub on my civic coupe?
  65. Help please?????
  66. Burst brake line replacement
  67. Pesky brake light
  68. No Brakes?
  69. 98 dx brake pads suggestions
  70. Disc brake conversion
  71. In search of si rims
  72. What is the best tire for 2004 Honda Civic Hybrid?
  73. Klutch Wheels // KM16 // Official Thread
  74. thoughts on beefy tires
  75. 97 civic brake master cylinder
  76. Klutch Wheels // SL1// Official Thread
  77. 2015 Klutch Wheels Line up
  78. Would these wheels/tires work for my car?
  79. Klutch Wheels Black Friday Sales
  80. Need help! Need to know if these wheels will fit!!
  81. Bent wheel hub.... SERIOUS
  82. offset help
  83. Wheel combo
  84. Brake line kink? and Clips...
  85. no brakes
  86. 98 Honda civic Hub center measurement
  87. Wheels balanced without new weights?
  88. Klutch Wheels - SL5 Silver Machined Chrome Lip
  89. Which wheel size is the best?
  90. 98 Civic EX 17" Rim Question
  91. 17's w 40 series tires on 99 sedan
  92. Klutch Wheels Integra SL1 Black
  93. Ring inside aftermarket wheels (redline)
  94. Wheel cover question
  95. Am I Kidding Myself? Mounting tires to wheels DIY
  96. 97 civic coupe
  97. What's the biggest Rim\Tire without rubbing
  98. Aftermarket pad choices
  99. ej6 hatchback wheel fitment!!
  100. Custom Painted Klutch Wheels
  101. Varrstoen V1's, Stance Mindset etc.
  102. Looking for Honda Rims
  103. Klutch Wheels : Right Hand Drive Honda Civic
  104. Klutch Wheels SL1 Bronze and Black Turbo Honda Civic
  105. New addition to the Klutch Family
  106. Klutch Wheels Mint Green Honda Civic
  107. 1st Post Need a steel wheel but confused
  108. Damond steelies on ek coupe
  109. 2000 DX brakeline from drum that wraps to cable
  110. 97 Honda Civic EX Persistent Brake Problem
  111. New all season tires for 1999 Civic
  112. Rims for my 98 Civic EX
  113. S2000 rims on 2000 civc DX??
  114. Tire recommendations for:
  115. Recommended Rim for my EK99
  116. New to the scene
  117. Help with Upgrading tires and rims
  118. Klutch Wheels SL1 16x9
  119. How to disconnect brake hose from caliper??
  120. will enkei 92s fit my 98 civic lx HELP!!
  121. Do I need to replace brake line if it got stretched?
  122. Klutch Wheels SL14 on Civic Si
  123. Need some advice or a suggestion
  124. Brake Pads Wear Extremely Uneven
  125. Klutch Wheels turning heads at Honda Day
  126. Klutch Wheels SL1 Black and Bronze
  127. tire size for 15x6.5 +40 wheels
  128. anybody have enduro # 716 tires?
  129. Klutch Wheels Help us Decide!
  130. EK3 96-00 Exi
  131. Klutch Wheels for Honda Civic
  132. Clunk noise from Brakes
  133. full-size spare tire?
  134. what kind of tires?
  135. Wheel help
  136. disk conversion
  137. Need help/suggestions!!
  138. 96 Civic DX front brake pads
  139. 99 Civic VP - Automatic Adjusters on Rear Brakes don't work
  140. diamond Racing wheels
  141. Which Stainless Steel Brake Lines for 2000 LX
  142. 5J or 5.5J for 185/65/14
  143. Klutch SL1 15x8.5 3.5" , 16x8 3", 16x9 4" step lip now available!
  144. Looking for a few cars to photoshoot/ wheels
  145. Newb: Tire Size Questions
  146. New Klutch 15x8.5 3.5 step lip on Honda EF Wagon, Fit most 6th Gen!
  147. street tire and drag radial
  148. 98 ek hatch
  149. loss of brake pressure
  150. What rims would look nice in your opinion?
  151. Rims
  152. Dementions for xxr 501 on 99 hatch??
  153. Brakes grabby / pulse-y (not in pedal)
  154. Any Help Appreciated, Rim/Offset help.
  155. Honda Civic 99 Rear Shoe Code
  156. 97 civic brake and fuel line replacement - Costly?
  157. break problem please help!
  158. 98 civic aftermarket offset question.
  159. brake fluid leak 97 ex
  160. wheel help, identify
  161. camber rear wheels
  162. Pictures of your Civic's wheels!
  163. Rear hub assembly installation ?s
  164. Baffled brake problem
  165. want to upgrade my rotors and brakes
  166. Give me ideas!
  167. how to clean rims
  168. Brake Overhaul
  169. Need help identifying center cap
  170. 99 VP - Rear Brake Shoes won't adjust automatically
  171. anyone know where i could get these rims used?
  172. Gold/White rims for cheap? thoughts?
  173. Car is Shaking! Help!
  174. Hx vs Ex vs Si brake system
  175. Hellaflush
  176. Measuring brake pad "service limit"
  177. brake interchangeability
  178. Kosei K1 TS light grey or Konig Lightning black with lip on 1998 Black civic sedan
  179. 15x7 +10 offset
  180. ran into curb :(
  181. 98 Civic Rims and Tires.
  182. My98ex pickin out wheels
  183. Rota gt3 hellaflush suggestions?
  184. Brake caliper wear indicators and when to change pads
  185. need info, ssr type c
  186. Rear brake line problem
  187. Want 16x8s, but will they fit w/o mods? (Eibach pro kit already installed)
  188. 2000 Civic rear disc conversion questions
  189. 18's on 97 civic
  190. I seek your help! What rims are these?
  191. Steelie paint ideas
  192. 97 civic lx rims and tires question? noob
  193. Clicking sound from brakes every revolution of the tire!
  194. 199
  195. recently got a job so anyone have specs on a good tired and rim size to be flush?
  196. Running different size rims front/back???
  197. Bronze or Gunmetal Rims on a blue 2000 Civic?
  198. Honda OEM Wheel Choices
  199. Brakes on 98 Civic EX coupe
  200. Who said braided brake hoses never split?!
  201. 205/40/17 or 215/45/17
  202. drilled & slotted rotors
  203. Changing Brake Pads/Need Quick Answers
  204. 99 DX Suspension Upgrade
  205. wheels squeak in reverse
  206. 5 lug conversion on a 97 civic
  207. Clicking noise when accelerate on front right tire
  208. hucaps, yay or nay?
  209. Brake Experts OEM Brake Swap Faq - Amazing information inside!
  210. tire and rim
  211. Need Lug Nuts for Hub caps - Civic coop 96
  212. 96ex wanting rear discs
  213. Tire help?
  214. Anyone know where i can find widened steelies
  215. Where can I get standard lugs with black rings?
  216. Rear Disc Conversion 1998 Honda Civic /EX/ABS/VTEC
  217. do rear wheel brgs come out of the hub?
  218. is this normal when i spin my tire?
  219. Driving issues at 60+mph...
  220. tire recommendation 98 civic
  221. wheel stud replacement on VTI EK4 hub
  222. Accord Rims?
  223. 97 ex
  224. drum brakes
  225. friend selling ls webs for 120 total..good buy?
  226. 2000 Civic Dx Disc conversion
  227. Mud Tires on a 2000 EX?
  228. My Civic 97 Coupe, Need Advice!
  229. Need new rims!
  230. 1998 Civic EX Rim Opinion
  231. want to change my rear drums to disks
  232. nankang tires
  233. Rear disc converstion PPV
  234. Don't know if these tires will fit my car.
  235. New tires
