street tire and drag radial
Old Aug 3, 2012
99em1boost's Avatar
99em1boost is an unknown quantity at this point
My 99 si currently has 15" steelies on it. I am planning on buying some Rota Slip Stream's but I cant decide whether i want 16's or 17's. I do want to lower the car pretty significantly. I will also be racing the car. Therefore I need help on a seperate rim set for front wheels so I can run drag radials. I don't know what size they would be, and how such a big tire and rim would fit on the front without having to make significant changes to the suspension and brake area in the front. In short I am looking for a drag race rim and tire size? Will I be able to quickly and easily switch with this drag radial set up and street tire set up? Also should my street rims be 16's or 17's? Thanks guys
Old Nov 17, 2012
EGhatchOwner's Avatar
EGhatchOwner is an unknown quantity at this point
Re: street tire and drag radial
You should definitely pick the 16' because there wont be any problem if you want to lower the car. Drag radials shouldn't be a problem...... The drag rims should be 15' or 16'.
SuperNova18
24
Sep 2, 2019 10:46 PM
alaga
25
Aug 13, 2015 04:42 PM
EM_WON
Jul 22, 2015 06:49 PM
bizspeed
Florida
Jul 14, 2015 08:40 PM
krazykoncepts
Jul 14, 2015 01:55 PM
