Steel wheels with 1 mm different ET
I've put new summer tires with wheels on my 1999 Civic Si. The new wheels and tires came off a 2008-2011 Hyundai Accent. The original wheel spec is 5.5Jx14 ET45 for the Honda. The Hyundai is 5.5Jx14 ET46. Will this cause any issues for the long run for safety, clearance wear and tear in the long run or anything else?
Also the studs don't tighten like they used to; is this a safety issue?
Thanks
JT
Thanks
JT
Re: Steel wheels with 1 mm different ET
As long as the steelies clear your calipers and suspension (they should), you'll be fine with no long term issues.
now, the issue with the studs now.. If you're on OEM rims, they use ball-seat lug nuts. I'm not 100% sure on Hyundai, but they might use conical seat (usually 60-degree taper) lug nuts, so you'll likely run into an issue there. The ball seat lug nuts will have a small ring of contact on the lug seat faces of the hyundai rims (instead of the entire surface of the lug nut seat making contact with the rim). If you're on aftermarket rims, they should have a 60-degree taper conical lug nut.
One solution is to get aftermarket lug nuts and get cone to ball seat adapter washer things
@Chezboat24 My response was delayed bc was dealing with work stuff, but I'm willing to bet OEM ball seat lug nuts and conical seat on the hyundai rims.
Hyundai rims are black steelies from the factory.
Is this what you mean by 'things'? Conical seat to Ball seat Adapters?
https://www.amazon.ca/Adapter-Washer-Convert-Degree-Socket/dp/B00LGZV2EG
https://motorsporthardware.com/product/conical-seat-to-ball-seat-adapter/
I can take pics and post if that will help clarify the issue.
usafstud
15
Feb 17, 2004 01:26 PM
iamboo
Oct 5, 2002 06:43 PM
