Brake caliper wear indicators and when to change pads
Old Jan 5, 2012
WaryDriver's Avatar
WaryDriver is an unknown quantity at this point
Question Brake caliper wear indicators and when to change pads
Am I supposed to drive until a wear indicator actually touches a rotor, or am I supposed to change pads just before one of the indicators touches a rotor?
Right now, I have a wear indicator 1mm from a rotor but the brake pad has a thickness 2-3mm greater than the suggested thickness for replacement.
I am new to brakes. Bought Duralast Gold ceramic pads from Autozone.
Old Jan 6, 2012
Gunner's Avatar
A true genius admits that he/she knows nothing.....CLOSED SAT/SUN
Gunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to allGunner is a name known to all
Re: Brake caliper wear indicators and when to change pads
I would replace them before it hits..if you wait you risk damaging the rotor itself..the indicator will actully cut a nice groove into it..they are there to let you know you will soon have no brakes.
Misfit2613
Brakes
26
Sep 1, 2018 05:02 PM
masongap
May 26, 2015 07:55 PM
rhvic
May 22, 2015 03:06 PM
ayoitzjulesdx98
May 14, 2015 08:29 AM
