Rear disc converstion PPV
Old Jan 26, 2009
jweb42055's Avatar
jweb42055 is an unknown quantity at this point
I just did another rear disc converstion on my 98 civic, i haven't installed the proportioning valve yet because i've been told it doesn't really make a difference unless you have abs. So my question is how big of difference will it make if i do install the proportioning valve from a SI? Also will i even notice the brakeing difference between the two.
Thanks
Old Jan 28, 2009
Zzyzx's Avatar
Autocross Junky
Re: Rear disc converstion PPV
depends on if you are threshold braking or not.
But seriously, who ever told you that the proper proportioning valve wont make a difference in a non-abs car does not know anything about brake systems.
Basically with out the proper proportioning valve you will have messed up your brake bias. which will have a drastic impact on your stopping distances.... when trying to break at the cars limit.
GolNat
Nov 27, 2018 03:32 PM
h4ldol
Apr 24, 2017 08:16 PM
Sep 27, 2015 11:33 AM
czarlun
Sep 14, 2015 08:16 PM
hatch90
Sep 3, 2015 08:45 AM
