is this normal when i spin my tire?
Just got a 97 manuel civic and when I shift gears my car lunges back and forth like when someone is learning standard. I lifted my front wheels and when I spin the tires back and forth there is play before it catches inside the transmission. Is this normal and could this be causing the car to lunge back and forth? Thanks
Re: is this normal when i spin my tire?
If both tires are off the ground and you spin them, they will spin until there is no momentum left. I don't know if we're talking about the same thing though. When you shift, how exactly are you releasing the clutch? Are you just dumping it? How off are you on the revs? If you're completely off, this would cause that bucking.
With the wheels off the ground, engine off, transmission in gear, you will get some play if you try to spin the tires back and forth. I have no idea how much play is normal.
It will be a good idea to check the play in the CV joints, they should not have any play.
Maybe you are not used to engaging the clutch smoothly enough.
Me thinks you looking at non-related stuff - wrong direction... as Tbohar stated above.
From another thread today:
https://www.civicforums.com/forums/2...press-gas.html
Touge
Ottawa
Jun 23, 2015 02:48 AM
Touge
Jun 23, 2015 02:04 AM
Touge
Ottawa
Jun 5, 2015 11:15 PM
bo_red
Apr 23, 2015 10:09 PM
