lowering 99 civic and have rim and tire size
Old May 30, 2016
Junior84's Avatar
Junior84 is an unknown quantity at this point
I have a 99 ex ..I'm lowering about 2 inches and was wondering if I go with a 16 or 17, what tire size will I need..I Def don't want any rubbing or scraping
Old Aug 25, 2016
Hutch1051's Avatar
Hutch1051 is an unknown quantity at this point
Re: lowering 99 civic and have rim and tire size
I have a 2000 ex and I had 17" inch verde rims with toyo 205/45r17 tires on and I had rub with a 2" tein s-type drop. it would rub constantly over bumps and in turns. The 205/45r17 wont mess your spedo up thats why I used them. If I was you go with a 15" inch with a 175 or 185/55 tire and your 2" drop will look the best. Honestly play it safe my firend. Good Luck!
Old Oct 14, 2016
Miss EJ6's Avatar
BPL Namdata
Miss EJ6 has a spectacular aura aboutMiss EJ6 has a spectacular aura aboutMiss EJ6 has a spectacular aura about
You'll need to run smaller tires for 17s, 45 profile is to large for 17s. I would recommend you use 195/35r17 or 205/35r17. You'll need to run with 30-35 profile tires with 17s to not rub. I run 195/40r16 on my 16x8.25 with 3.5in plus drop, 175 is to thin stock 15in tire size that Come on the SI model are 195/55r15.
vichonda
Oct 31, 2016 12:33 PM
TS2008
May 14, 2016 03:00 PM
ricerocket38
19
May 13, 2016 01:39 PM
Gabegv
Apr 22, 2016 01:38 PM
