View Full Version : General
- Hey guys I have a problem, I have a 13 Civic that I can't turn traction control off b
- 2009 civic, vibration during acceleration in a narrow speed range
- Honda civic 9th gen intermittent noise when AC is engaged
- Key fails intermittently
- 2013 what to do about headlights
- Unsure what this sound is. Sounds expensive.
- 2007 ABS, SRS, Engine, BRAKE Lights etc.
- 2007 Ex Rattle and Issues.
- Strange but complecated problem
- New 2010 civic
- Mystery double beep when in motion
- 2013 Civic - How to Remove Key Blade from Fob?
- Rat getting in my 06 civic sedan
- OEM or aftermarket TPMS sensors
- How to run the car on jacks?
- What workshop manuals are available?
- Torque Rod
- What is underneath my car?
- What attaches to this bracket?
- A Burning smell when I spped up fast
- Replacing lock cylinder
- Wheel Covers for 8th Gen 16" - Using 2019 10th Gen
- Hubcap Hell
- Loud Road Noise
- Re: squeecking noise when i reverse..
- 2006 Honda Civic Ex Sedan 1.8L (RADIATOR FAN NOT TURNING ON)
- Burning smell
- Guidance
- Security Alarm question
- Noise form engine bay - AC Compressor? Help.
- adding cruise control to a 2010 civic
- Missing Oring
- What is this red light?
- Undetermined front end rattling noise
- Starter relay fuse location
- Loud Fuel pump.
- oil leak: 1 mechanic said it was oil separator & other said 2013 has no oil separator
- Re: Weird Sound Civic IX 1.8 iVtec
- 2012 Honda Civic LX - Won’t start
- Weird Sound Civic IX 1.8 iVtec
- Shudder at low rpm after shifting gear
- Rattling/Vibration Center Console 2009 Civic
- Advice please: 2006 EX
- 2008 Honda civic takes a bit of time to start
- Brake Light
- Cannot open the door with key from outside
- Help
- Cheapest place to buy screws & bumper clips?
- Check TPMS system constant
- 2013 Civic Sedan Fuel Door Won't Open
- EPS , TRANSNMISSION and ENGINE LIGHTS ON
- Rattle Noise Honda Civic 8 gen. 1.8 petrol.
- 2012 Civic - Is this car safe to continue driving?
- Fuel gauge would not get full
- 2007 civic si coupe
- 2006 Coupe Help
- HELP! NEED Owner's manual
- Possible leakage under my car
- Weird noise from front left tire when turning right
- Unknown screeching noise
- key will not go into trunk lock [solved]
- 2010 Civic LX 4D, PCV and wiper motor
- 1.4 Civic 2007 Parts/Repairs: Advice Needed
- 8th gen civic
- Door lock clicking/cycling
- 2008 Honda Civic EX Mystery Leak
- Tacky/Sticky Plastic
- Heat & Emission System Issue plz help
- Can you identify this part ?
- Outside air temperarture location
- New to Me 2012 Civic EX - A few questions please..
- New Member need help w/ Diagnosing plz
- Help Finding Parts/Part Recommendations
- Part ID
- Help: what part was stolen from my car?
- 2014 civic ex sedan
- Vibration issue
- 2011 civic TPMS fix
- Mileage - How far it can go?
- Maybe fan issue
- 2 mystery noises - 1 potentially wheel/suspension and 1 potentially belt related?!
- Whistling noise when over 4000 rpm ? Vacuum leak??? HELP
- 2010 Honda Civic - Grinding noise.
- Car alarm won't shut off
- 2012 1.8 Petrol Auto
- 2012 Honda Civic lx
- Loud screech
- Car cuts out
- Cylinder head Casting Codes
- 2007 Honda Civic cruise control not working
- power steering fluid
- Changed Starter and Now I have check engine light on!
- Wknt accelerate while cold, rpms still raise, screetching/grinding sound
- What is this cable?
- Noise when I go in reverse
- Honda Civic 2008 Common Problems?
- 2015 with 50K miles humming sound at speed
- "Check Airbag System" warning light
- Possible dirty/bad injector?
- Best direct replacement fuel pump?
- Odometer won't display & Oil Life won't reset
- 2010 EX sedan loud grinding from engine bay with no warning lights
- 2013 LX with 400,000 KM
- Low gas mileage concern
- Copper Anti-Seize vs Aluminum Anti-Seize o2 sensor, spark plugs, brakes
- Shift lock keeps engaging
- 2008 Civic no heat
- Honda '13 Horn
- p0504 powertrain
- civic mk9 locking and alarm and warning lights
- 2008 Civic, Shakes under accel
- Check EPS system
- Forward Facing Child Seat
- ECM Problems
- Help with identification
- Anyone know what this sound is?
- Rough Idle when A/C is "OFF"
- key wont turn in ignition, steering wheel not locked.
- honda civic 2007 . low gas mileage
- 8th generation SI replacement questions
- Engine issues after valve cover gasket job
- 2010 a/c control panel
- bad fuel mileage
- 2010 civic cog under car visible... missing panel?
- 9th Gen Articles?
- Fuel gauge issues
- Loud buzzer/foghorn noise
- Vibration
- 2009 Civic SI VSA light
- tranny maintenance
- 2014 1.8 L Spark Plugs - other
- The lengths of the driver’s seatbelt in the 9th generation Civic
- 2011 Civic Growling/turbocharger sounding noise?
- Sporadically, slow cranking, not starting right away
- Drone sound and vibration throughout car
- newby
- The cold weather problems of the 9th generation Civic
- 2011 Civic DX Ticking/vibration
- 2010 honda civic
- Intermittent scraping noise 2015 Honda Civic
- cooling fan noise 2011 civic coupe?
- 2007 Honda Civic Hybrid Clicking when accelerating
- 2007 Hybrid shudder/vibration after stop then go
- 2009 Civic Si questions
- 2007 Honda Civic EX Coupe OEM service manual.
- Shaking problem when starting up car
- Debris in ventilation system - rodent nesting?
- 08 Civic LX - front right side rattle
- Horn, power side view mirror, and transmission switch circuit issue (maybe ecu)
