General Post General Issues questions here that does not fit other sections
EPS , TRANSNMISSION and ENGINE LIGHTS ON
Old Jul 20, 2021
elerz91's Avatar
elerz91 is an unknown quantity at this point
Hi all
yesterday after changing my battery all the 3 engine eps transmission lights turned on
at first I thought its an electrical issue but then I experienced gearbox problems light heavy shots , lost speed meter , gear changing failure and finally roughness of steering wheel
i have no idea exactly what’s the problem
mechanic says i have to change the whole gerabox
Old Jul 20, 2021
Re: EPS , TRANSNMISSION and ENGINE LIGHTS ON
what codes?
Old Jul 20, 2021
FRSam's Avatar
Click Here
Make sure your battery terminals are clean and tight. Try disconnecting and reconnecting. It’s highly unlikely that you need a new transmission.
Old Jul 20, 2021
Colin42's Avatar
I'm guessing the terminals aren't tight enough
Old Jul 20, 2021
elerz91's Avatar
Thanks all
i will check it
but i have serious problem with transmission like heavy shots when i change gear to D, vehicle jumps when i turn it to D
the D light blinks all the time
and the steering is not smooth like before
car is lazy when i push the paddle
the error goes for Shafts and speed sensor
it also says the comparison between engine speed and transmission speed is not proper
Old Jul 20, 2021
elerz91's Avatar
I tried to remove the errors with system check
it goes away and appears again after some hours
Old Jul 20, 2021
looks like you might have a trip to the dealer soon
you did not check what codes you have?
Old Jul 21, 2021
BrotatoChip's Avatar
Super Moderator
Fix the electrical issue before worrying about the transmission.
Ricky Bacon
Electronics
Feb 24, 2021 06:06 AM
Tenpin
Electrical
Nov 18, 2019 08:42 AM
TSSCivic
Mar 8, 2014 03:23 PM
BlueInkAlchemis
Jun 22, 2009 02:08 PM
