Engine Shuts Off
Old Mar 7, 2014
TSSCivic's Avatar
TSSCivic is an unknown quantity at this point
Engine Shuts Off
I have an 02 EX with auto tranny. As I was driving home before, the engine just shuts off when I was on the highway. No indicator lights came on, just both the RPM & speedometer needles dropped to zero, then within seconds, all the indicator lights went on.
I pulled aside, put the gear in park, & turned the engine back on. The engine started immediately without any issue. All of the indicator lights were off, so I was ready to drive again, within seconds, the engine shuts off again. I started the engine again & the engine starts immediately without any issue.
No check engine light
This happened near the exit so I exited the highway. The car was fine, the engine ran normal, then about 2 minutes later, the engine shuts off again but this time it started by itself almost immediately. I didn't have to stop the car & turn it back on.
Now I just went straight home. Where I live is about 5-10 minutes away from the highway. The car was fine. The engine did not shuts off. I drove around my neighborhood to see if the engine shuts off again or not. After driving around for about 5 minutes, the car was fine, the engine did not shut off.
Within the last 6 months, I got a new battery & replaced all the spark plugs.
Any advice or input about this will be much appreciated.
Thanks for reading
Old Mar 7, 2014
mikey1's Avatar
Re: Engine Shuts Off
battery terminals tight?
loose ground connection?
Old Mar 7, 2014
Poopies's Avatar
Super Moderator
When was the last time you changed your timing belt?
Old Mar 7, 2014
TSSCivic's Avatar
I checked the battery terminal & they were tight.
As for the timing belt, I changed it few years ago, I think around 80K-90K miles. Right now the car have 171K miles
Old Mar 7, 2014
mikey1's Avatar
check ALL the major ground connections, not just the battery,
grounds to the frame, ground straps from the engine to the frame etc etc
could also be an intermittent fuel pump issue
Old Mar 8, 2014
TSSCivic's Avatar
Thanks guys for all the input & advice.
I checked everything from the battery, ground, spark plugs, & cleaned up the throttle body. Everything was good.
Since I couldn't find anything wrong with the connections, I took it to a local shop that I always go to for some opinion. The mechanic also checked everything & he said he couldn't find anything wrong.
Well, after that night, everything works fine. I don't know what happened on that night. Hopefully it won't shut off again.
I probably going to replace the timing belt within the next few weeks.
Xuhme
21
Aug 7, 2023 03:40 PM
CarStuff
Dec 6, 2020 12:52 PM
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
redej2
Apr 29, 2015 01:47 PM
smmahan
Apr 15, 2015 08:17 PM
