General Post General Issues questions here that does not fit other sections
Check TPMS system constant
Old Jul 28, 2021
LaneM's Avatar
LaneM is an unknown quantity at this point
2014 Civix LX (whatever bottom of the barrel is). Had new tires put on. TPMS system resets until it is driven, stopped and restarted. TPMS check comes back on. Dealership tells me that if the incorrect speed rated tires are installed, the TPMS system won't work. They told 89H is the required speed rating. The tires installed have 89S speed rating. Can anyone out there in Hondaland verify this as true? Will a lower rated tire 'mess' with the TPMS system? Thanks, LaneM
Old Jul 28, 2021
Re: Check TPMS system constant
?!? Not sure if the 2014 uses actual sensors or calculates the number of rotation per minutes, but speed rating have nothing to do with it.
If it is calculated, softer tires will impact the calculation (deform to a smaller diameter at the contact point). But speed rate does not define if a tire is soft or not. It's a matter of having a smaller diameter or not at the contact point to the ground.
check if tires are at same pressure, if not, inflate the tires to same pressure.
Old Aug 4, 2021
redlion4's Avatar
redlion4 is a jewel in the roughredlion4 is a jewel in the roughredlion4 is a jewel in the roughredlion4 is a jewel in the rough
Possible that one or more of the TPMS sensors are going bad and need to be replaced?
xRiCeBoYx
General 10th Gen
Jul 27, 2021 06:56 PM
BluCoupe
Apr 1, 2017 04:35 PM
alaga
Feb 28, 2016 02:19 PM
trev0006
Apr 27, 2006 02:55 PM
blackcivic03
May 3, 2005 08:54 AM
