General 10th Gen Got a question or want to post but it doesn't quite fall under any other topic? Post up here!
10th Gen Civic Manuals
Old Jul 27, 2021
If you're in need of a service manual for your FC/FK 10th gen Civic, look no further. Also, owners manuals are at the end (linked straight from Honda's website. I'm not downloading them, so hopefully those links don't die).
>>>Full PDF Download here<<<
Each section (listed below) is its own PDF file
Password: *CivicX*
Yes, it's case sensitive. Yes, the asterisks are included.
Table of Contents:
  1. Service / General Information
  2. Maintenance Minder
  3. DTC Index & Troubleshooting
  4. DTC Advanced Diagnostics
  5. Engine Mechanical System
  6. Engine Cooling System
  7. Engine Lubrication System
  8. Engine Exhaust System
  9. Turbocharger Control System
  10. Fuel and Emissions Systems
  11. Fuel Supply System
  12. PGM-FI System
  13. Catalytic Converter System
  14. PCV System
  15. Electronic Throttle Control System
  16. Intake Air System and Exhaust System
  17. Starter Overhaul
  18. EVAP System
  19. Ignition System
  20. Cruise Control System
  21. Charging System
  22. Volt Battery Removal and Installation
  23. Clutch
  24. Manual Transmission
  25. CVT System
  26. TCM
  27. Brake System
  28. Electric Parking Brake System
  29. VSA System
  30. Driveline/Axle
  31. Front and Rear Suspension
  32. Adaptive Damper System
  33. Wheel & Tire System
  34. TPMS System
  35. Power Steering
  36. Steering Wheel and Column
  37. Climate Control System
  38. HVAC
  39. Audio and Visual System
  40. Navigation System
  41. CAN Communications
  42. Driving Support System
  43. Lane Keeping Assist System (LKAS)
  44. Keyless Access System
  45. Immobilizer System
  46. Interior Trim
  47. Dashboard Center Console
  48. Power Mirrors
  49. Gauges System
  50. Horn System
  51. Power Window
  52. Seat System
  53. Seat Belts System
  54. SRS Airbag System
  55. Moonroof System
  56. Lighting System
  57. Exterior Trim
  58. Windows Glass and Mirrors
  59. Bumpers
  60. Doors
  61. Tailgate System
  62. Trunk/Lid/Hood
  63. Wipers/Washers
  64. Body and Paint
  65. Body Repair
  66. Body Control Module
  67. Socket/Fuse/Relay/Switch
  68. Wire Harness and Ground Locations
  69. Electrical Wiring Diagrams
_________________________________________
Owners Manuals (pre-facelift, 2017 manuals linked):Navigation Manuals (pre-facelift, 2017 manuals linked):Owners Manuals (post-facelift, 2020 manuals linked):Navigation Manuals (post-facelift, 2020 manuals linked):
tricon23
Mar 7, 2007 04:47 PM
trev0006
Apr 27, 2006 02:55 PM
WEAPON-R CIVIC
Oct 6, 2005 05:59 PM
blackcivic03
May 3, 2005 08:54 AM
Bluelle
Apr 4, 2002 02:28 PM
