General Post General Issues questions here that does not fit other sections
2009 Civic Si questions
Old Mar 4, 2015
swmyers57's Avatar
swmyers57 is an unknown quantity at this point
Question 2009 Civic Si questions
New to Honda and this forum. Just purchased a 2009 Si, 6 speed, 105,000 miles. Wondering if someone could tell me if the following things are issues I should have checked out.
First, my VSA light comes on occasionally but resets after restarting the car.
Second, when I run down to one or two bars of fuel the CEL comes on and the car runs rough until I refuel. Running 93-97 octane. Sets a P0302 code but runs fine after I refuel. CEL also goes off after refuel.
Third, when I wind it out a little between shifts RPM's don't drop when I push in the clutch to shift. My son tells me this is normal for this car?
Thanks for any input.
Old Mar 4, 2015
Re: 2009 Civic Si questions
Need more info before deciding what to do about this. Got the code?
Seems easy enough to avoid, just refuel earlier than 2 bars.
I'd be wondering about what's in the bottom of the tank and what the filter "sock" on the bottom of the pump or cup looks like. Sounds like the pump might be sucking air due to clogged sock.
I understand that's normal to hang the RPM high briefly even though you took your foot off the gas pedal.
Old Mar 4, 2015
swmyers57's Avatar
Smile Re: 2009 Civic Si questions
Thanks for getting back to me ezone. I forgot to mention the VSA system is not throwing a code. The owners manual states that if the light comes on while driving there is a problem and should be checked out but I've had other Honda owners tell me they experience the same thing. Just trying to decide whether I should have it looked at.
As far as the fuel thing I was thinking along the same lines as you. I don't have experience with imports at all since I'm an old American muscle car guy. Guess I'll need to get a service manual and do some reading. I am having that problem looked at on Friday.
Thanks again.
Old Mar 4, 2015
What are you using to check codes?
Honda HDS scanner can probably garner more info than any other scanner, and can do the neutral position learn procedures if necessary.
Gotta have someone who knows what they are doing though, the scanner can't solve problems itself LOL
Old Mar 5, 2015
swmyers57's Avatar
Thanks for that bit of info. I just used a general over the counter OBDII code reader. May have to pick up the HDS unit.
Old Mar 5, 2015
OBD2 is only for powertrain (engine and trans). There's a whole bunch more on the cars that those code readers can't touch.
Old May 17, 2019
GutjosGT3's Avatar
Gutjosgt3
GutjosGT3 is an unknown quantity at this point
Can anyone tells me if there is a fix for the VSI light issue, is very annoying and the cars seems to stall around 4,00 rpm and there isn’t any codes, but only stalls when the light is on only. Please some tells me what is the fix because I’m about to dump this car and never get an SI
Pro_rock
Mar 27, 2017 11:50 AM
HI34
Nov 2, 2015 08:53 PM
Coldpizza
17
Feb 13, 2014 05:25 PM
ryan92.h
Aug 17, 2012 09:00 AM
michelle6818
Mar 4, 2012 06:53 PM
