General Post General Issues questions here that does not fit other sections
honda civic 2007 . low gas mileage
Old Jul 15, 2019
Manasmakkar's Avatar
Manasmakkar is an unknown quantity at this point
Hi i have a Honda civic 2007 at and its mileage is really low ... Somewhere around 7 to 8 kmpl in city . how to deal with it... And at times in neutral my rpms keep shuffling up and down . Need help .
Old Jul 16, 2019
GolNat's Avatar
Prelude Owner
Re: honda civic 2007 . low gas mileage
CEL on?
Old Jul 16, 2019
yes there is air fuel ratio error on the scanner ... And the cel is on
Old Jul 16, 2019
Colin42's Avatar
well that could certainly cause fuel mileage problems. sensor probably needs to be replaced, make sure its plugged in first. and buy either a denso or ntk
Old Jul 16, 2019
Is it the upper sensor or the lower sensor ... There are 2 sensors .. The upper i mean near my engines face .. And lower below near the suspension
Old Jul 16, 2019
Colin42's Avatar
upper
Old Jul 16, 2019
Thanks alot .. How much does it effect the mileage .
Old Jul 16, 2019
GolNat's Avatar
Prelude Owner
It can reduce it by 20% or more.
Old Jul 17, 2019
Are you sure it is the upper one that goes faulty always .
Old Jul 17, 2019
GolNat's Avatar
Prelude Owner
Either one can go bad depends on what the CEL is and what kinda problems you are having. The upper one determines A/F ratio while the lower one checks to make sure catalytic converters is working properly.
Old Jul 17, 2019
It is an air fuel ratio error so hence it might be the upper one .Thanks for helping .
Old Jul 17, 2019
GolNat's Avatar
Prelude Owner
Yes the upper would be the problem and you are experiencing bad gas mileage which is another symptom of it being bad.
Old Jul 17, 2019
Ordered an upper one .. Today ..it is P0135 code the error
Old Aug 5, 2019
P0135 even after air fuel ratio sensor change .
Old Aug 5, 2019
GolNat's Avatar
Prelude Owner
You did a ECU reset?
Denso or NTK sensor?
Old Aug 9, 2019
Its a denso .. The mechanic did clear the code after installing it through the sensor but it reappears . how to reset the ecu system ?
Old Aug 9, 2019
I had another issue today in which the ac fan motor was running slow and that lead the coolant to come out twice from reserve coolant box so i changed it. Would it again happen or was it just because of the ac fan running really slow .
Old Aug 12, 2019
My car overheats even after getting the car cooling system checked completely .
Old Aug 13, 2019
GolNat's Avatar
Prelude Owner
Head could be warped depending how bad it overheated.
Old Aug 13, 2019
I just got a head gasket changed a few days ago .But its even bad after the job done . however the temp Meter shows no signs of overheating even after the ac fan motor replacement but i feel the heat when i open the bonnet
linton23
Sep 7, 2013 09:22 AM
manchester
May 24, 2011 02:25 PM
taufichidayat
Jan 12, 2008 06:32 PM
milstein100
Nov 10, 2007 12:02 AM
rick93684
Sep 19, 2007 02:05 PM
