General Post General Issues questions here that does not fit other sections
Changed Starter and Now I have check engine light on!
Old Feb 3, 2020
Johnsoto11226's Avatar
Johnsoto11226 is an unknown quantity at this point
Hey friends,
Have a 2007 Honda Civic LX wich had a bad starter replaced. Moment I pick up car and drive away I get check engine light. Error codes are P0135 & P0498. How can I properly diagnose these issues first before ordering the parts. Are there fuses I can check?
Old Feb 4, 2020
Wankenstein's Avatar
Re: Changed Starter and Now I have check engine light on!
Originally Posted by Johnsoto11226
Hey friends,
Don't rush to order parts without any type of diagnosis. Take it back to the mechanic, tell him what happened and ask him to read the codes + do a live data scan on it. Afterwards, ask him to clear the codes to see if they return. They shouldn't charge you a fee.
Old Feb 4, 2020
Hey brother. He cleared the codes but it returned it seems. Not sure if I should check fuses first
Old Feb 4, 2020
Prior to bringing your car to this mechanic you didn't have any CEL's correct?
After this mechanic did a starter replacement you now have two CEL's as soon as you left his garage..coincidence?
Old Feb 4, 2020
Same thing I thought. If I had a garage I would work on my own car
Old Feb 4, 2020
So, he isn't claiming any responsibility? At minimum he could at least help you diagnose the problem to narrrow down the resolution and possible cost involved.
Old Feb 4, 2020
One free thing you can try is checking all engine and chassis grounds for tightness and cleanliness. You can also try clearing the codes by (ecu reset/idle relearn):
https://www.civicforums.com/forums/1...-question.html
Old Feb 4, 2020
Mechanic said he only change starter and thats it but I take everything with a grain of salt that people say.
You've been an amazing help. Im usually pretty busy now that I have been blessed with 2 kids so When I have time I plan to work on car
Old Feb 4, 2020
BrotatoChip's Avatar
Super Moderator
P0135 is for A/F Sensor (Sensor 1) Heater Circuit Malfunction. I don't know these engines very well but this sensor is right on top of the exhaust manifold. It's possible the mechanic either had to unplug it to get to the starter or damaged it while replacing.
P0498 I believe is for the EVAP canister vent shut valve. Couldn't find it in the 2007 service manual but that's the description from another generation. I don't know if the mechanic could have caused this.
gabrown2
Apr 11, 2015 08:22 PM
JohnnyBxo
Nov 3, 2014 10:35 AM
iceshade
May 27, 2014 12:29 PM
mclld
55
May 5, 2014 06:07 AM
Ralph48
Feb 24, 2013 08:39 AM
