General Post General Issues questions here that does not fit other sections
2014 1.8 L Spark Plugs - other
Old Apr 29, 2019
Timbogates's Avatar
Timbogates is an unknown quantity at this point
Since I have the 1.8 L what spark plug provides the best life for this engine? NGT or Denso Should you use any dielectric grease on the threads too just not near the tip?
What will be the sign of a ball joint or tie rod problem on these vehicles from just wearing out? Around 150,000miles?
How often are the rear shoes and drums need to be turned/replaced? 100,000 or 130,000
Old Apr 29, 2019
Re: 2014 1.8 L Spark Plugs - other
The factory installed NGK # DILZKR7B11GS
Best LIFE? The precious metal plugs wear so slowly they could outlast the car, so long as they don't get fouled (fleabay discount replacement warning: counterfeit spark plugs don't last)
If it were my personal car, I'd probably pull the 4 plugs out and see if I could find a reason to replace them.
Not dielectric grease, that's an insulator. .
Honda says use anti-seize on threads, but the NGK website says don't use anything on threads.
FWIW I install them dry.
Free play.
Remove drums and inspect. Then decide.
Unless you deliver pizza or newspapers for a living, they are probably not worn very much.
HINT: My dealer does not stock brake shoes for any Honda, because we don't sell them
CarbonFly
Jun 17, 2003 01:27 PM
nbpEMCivic
Oct 17, 2002 10:46 AM
platinumx310
Sep 24, 2002 11:07 PM
platinumx310
Sep 14, 2002 12:50 AM
atom80
Jun 29, 2002 09:42 PM
