General Post General Issues questions here that does not fit other sections
Shift lock keeps engaging
Old Oct 30, 2019
99integra's Avatar
99integra is an unknown quantity at this point
What's up, I have a 2011 Civic LX and I have to manually disengage my shift lock Everytime I put it in park. Happened after I pumped the brakes a few times with the car in park. Is there a fuse or solenoid that controls this and if so how would I go about fixing it. Thank you!
Old Oct 30, 2019
99integra's Avatar
Re: Shift lock keeps engaging
On top of this I found out my brake lights don't light up when the car is off but work when the car is running. Never did that before.
Old Oct 31, 2019
BrotatoChip's Avatar
Super Moderator
Check fuse number 10 (7.5 amp) in the under-dash fuse box.
Old Oct 31, 2019
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
Bad brake pedal position switch or switch pad missing?
Old Oct 31, 2019
99integra's Avatar
Now this morning I found out that my brake lights weren't working unless I pumped the brakes a few times. Seems to have fixed itself for now though. Going to assume a bad pressure switch. Not very fun almost being rear ended at 6 in the morning.
Old Nov 2, 2019
99integra's Avatar
Turns out it was the brake switch, replaced it and all is good!
extreme58
Oct 9, 2017 06:44 AM
94Coupe94
Jan 7, 2016 09:02 PM
tjk34
24
Oct 31, 2013 10:39 PM
s7khan
Transmission
Mar 6, 2013 10:27 PM
civiclized
May 2, 2003 01:56 AM
