General Post General Issues questions here that does not fit other sections
Anyone know what this sound is?
Old Jul 30, 2019
Rkane3640's Avatar
Rkane3640 is an unknown quantity at this point
See attached video
it’s sounds like there is an helicopter flying overhead, but under my hood.
08 civic SI , 180k miles, electronic PS, new alternator, new compressor, good oil level, new starter, any thoughts?
Old Jul 30, 2019
Slumpertcivic's Avatar
Re: Anyone know what this sound is?
Exhaust touching the frame?
Old Jul 30, 2019
Rkane3640's Avatar
God I hope so, that would be a lot easier if a fix than anything else. I did push up against a parking barrier the other day, so that is a definite possibility, and other thoughts out there in the forum?
Old Jul 30, 2019
piano55man's Avatar
piano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of lightpiano55man is a glorious beacon of light
I couldn't tell, but if it's following the rpm's....then it could be rod bearing.
How many miles on the engine?
Old Jul 30, 2019
Rkane3640's Avatar
180k miles on the motor , it’s an off sound tho, not a click or a knock , kinda like a dull buzz or like, idk it’s hard to describe. The video is hard? It’s not following my RPMs too much, I cannot tell if they are correlated. Don’t listen in the video for when I am revving it, it subsided when revved. Listen in between, that isn’t background noise, it’s the car
Old Jul 30, 2019
piano55man's Avatar
have you checked your accessory belts?
when was the last time they were replaced?
also, when was the last time the timing belt was replaced?
Old Jul 30, 2019
He has postied in wrong forum so that confuses things.
He has a 08 Si so it’s a timing chain.
Old Jul 30, 2019
piano55man's Avatar
lol....
Old Jul 30, 2019
Colin42's Avatar
moved to the correct section
Old Jul 30, 2019
Rkane3640's Avatar
When I put my ear near the top
of the motor it sounds more noticeable, but I cannot tell if it’s coming directly from from the motor or somewhere underneath. The accessory belt is not new but I checked it, looks good. The sound is getting a little more whiney toward day’s end. It almost seems to be coming from around the block or trans. Or just generally down in that area. Could be a perforation in the exhaust but I can’t find it if it is. Could it be a bad water pump? Any other symptoms of that besides a whine? I haven’t had any overheating issues yet. I don’t know I’m just spitballing here
Old Jul 31, 2019
Rkane3640's Avatar
Updated video: What is this sound!?
Please see attached, please let’s me know your opinion. What is this sound? More info in video
08 Honda Civic SI
Old Aug 1, 2019
colewan's Avatar
colewan is an unknown quantity at this point
Probably exhaust system
sp1966
Jan 26, 2018 08:51 PM
MarkoPollo
Aug 16, 2014 06:19 PM
Nintensity
Apr 22, 2013 08:10 PM
em2maxamillian
33
Nov 9, 2012 01:42 PM
stewartfan
May 30, 2012 11:08 AM
