- New member, ? about skunk2 manifold on D16Y7
- good websites?
- b18c1 gsr axle problems in my civic
- (newb) Can I use any 6th gen power steering in my 97 CIvic CX?
- new shoes!!
- Bench test an ECU?
- headers/manifold/throttle body mods on a y5??
- Need Some Help on choosing......
- My Car was stolen!!!!!!
- Driver side floor mat hook
- New to forum
- Cluster Swap
- hi all, new to the civic world. just had a question about my 97.
- Heater control not working
- STOLEN CAR: Red 1999 Honda Civic EX coupe
- Exhaust Manifold
- need new exhaust manifold
- What to do with my 1996 honda civic ex
- sup all...new to forum
- 2000 Honda Civic EX suspension question
- HELP! My 2001 EJ9 wont start!
- need help with seat rails
- new to here
- Reverse shift scraping?
- 99 EX 4 wheel disk brakes?
- 1997 Honda Civic FOR SALE
- cant decide between cold air or dry flow
- Exhaust - 96 DX
- I think i blew my Clutch!
- VTEC CEL Help
- new transmission and engine :)
- LED tail light install HELP!?!
- timing belt question
- REAR bumper and clutch HELp!
- 1996 Civic braking noise
- Location of Vtec Solenoid Valve and Oil pressure switch on 98 Civic
- New Rims having a problem
- 2003 civic si steering wheel in 2000 civic si help
- throttle body question
- little cold air intake trouble
- D16Y8 cheap engine mods
- Coolant level drops after radiator flush and new water pump
- DIYs for 97 honda civic EX
- help need k20a3
- 97 civic exhaust system
- headers installation question
- CXI shift speeds
- Civic sitting crooked
- Good deal? Civic type r engine ?!
- Honda civic d14a4 turbo Problems???
- my old car
- backfire while accelerating 97 LX
- cruise control prob
- Is modding this engine worth it?
- 98 Civic DX
- 97 civic sunvisor clips
- Transmission question
- Best Bolt-ons for 1999 civic ex
- Tranny help! grinding into seccond...
- Air Suspension for 99 ex
- 98 ex speedometer problem
- Please take a look at this pic
- My AC system has been removed!
- Need thoughts on actuator problem
- Looking for a Stock Air Cleaner 98 Civic EX
- need help. rear window
- shaved back???
- big problem, loud clanking, engine light
- question???
- Having Fuse problems
- 96 LX Getting 20 mpg !?
- 98 keyless trouble
- dropzone springs
- Minimum engine modifications to mount a turbo
- front bumper
- tranny swap question
- sputtering and dyin' please help
- Eyelids with deflector...opinions?
- 99 hatch problems
- Just Bought a 97 Canadian EX....
- helicoil
- Question for the 6th Gen Civic pro's
- Prelude Seats
- H22A Swap, Need Some Info
- Automatic to Manual
- stranded in Boston with engine problms on an acura 1.6 el
- 97 LX...What to do next?
- Lowering spring ???
- clutch problem
- d16y7 mods!?
- CAI Help
- 1996 Hatchback DX instrument panel
- d16z6 cam in D15b
- High idle on D16y8 replacment motor, hours of toruble shooting, no fix yet
- D16y8 Intake wiring, I need help!
- Wierd Stuttering problem at 2k rpm
- 02 hatch. what should I be paying?
- 97 Interior
- Please help! D16Y7 running rich
- hey i need some help not too important ecu question
- 98 dx headlights/interior lights surge at highway speed?
- Some 96 hatch Q's
- HELP! 97 Civic HX trouble...
- 97 EX AT issues!! please help!!!!
- Please Help Replace My Exhaust Manifold
- 1999 Honda Civic CXi too noisy!!! help!!!!!!
- 98 civic exhaust?
- 98 civic security system
- Civic LX Shifter Knob
- Headlights
- '97 Civic LX 1.6 4Dr Water Pump & Fuel Pump Question
- 3rd gear grinds...
- Help with the law of brake lights
- civic dx power steering?
- 2000 civic chugging
- 98 DX dash light
- looks are always nice..
- best bang for your buck engine? >2000 civic cx<
- indiglo gauges
- Disappearing oil and coolant 96' civic LX
- 98 civic hx m/t toasted at 84,000?
- Help! 96 Civic major engine failure!
- performance upgrades
- catalytic converter missing?
- 96 exhaust d16
- Clutch acting strange
- Hello
- Itegra Cluster swap
- D16 Tranny leaking tanny fluid HELP
- alot of problems at once....
- What's up? I've owned 3 Civics and I have never been here before!
- AT shift linkage broken, stuck in park, how do I unlock wheels?
- Strange violent tugging
- 1997 honda civic CX HB, body kit
- civic idle problem
- AEM short ram on a 98 LX
- 00 VTEC exhaust manifold same as 96-98 VTEC?
- Overheating. HAs me stumped
- Ignition wire
- headlight bolts
- Paint code for 2000 Black Civic coupe
- Gas Performance in Cold
- aftermarket for b16a3
- CrankShaft Sensor
- 2000 civic VAFC settings?
- flowmaster muffler
- My brakes suck
- Ebay EXhaust would this work
- turbo time...
- Airflow??
- Ran out of gas, now car runs like crap
- 1996 Civic wiring diagram for Turbo Timer
- $500 how to spend?
- Cant pass CA smog- Engine light-wont throw right code? help asap
- air coming out of the engine Oil Cap
- H series in da EK 5 lug and stuff
- what is the benifit of using a one step colder spark plugs?
- 98 Civic LX power window problem
- whistling noise
- map sensor
- New car and new mods
- hids in projectors
- wont start
- leather seats
- 92 LX oil leak
- Rust on bolts on exhaust manifold cover
- Location of VSS wire 1998 Civic EX
- loose shifter
- Help. The bottom Fuel Filter nut would not loosen
- whistling noise again
- new 98 civic lx owner!!! I was thinking..
- Intermittent Belt Whine
- Fuel pump?...or? please help!
- 96 Civic Problems
- Drag Wheels
- Wtb: B18b Ls
- Transmission compatibility
- 05 cluster swap
- 6th gen mileage
- power window problem on 1997 ek
- Winter hates me!!
- looking for mass air flow sensor
- How Do i get rid of the cruise controll?
- 98 civic manual trans removal help
- Oil Pan Replacement?
- 1997 Civic EX Coupe AT
- Remote starter help
- Popping noise when I turn my car
- Interior questions
- ebay turbo
- fix ecu
- broke down si
- 2000 hx interior
- 1999 Civic H22 Swap.
- 02 Sensor
- Sway Bar question
- Would you recommend this civic?
- Question about manual transmission compatibility
- Shes finally done!
- New 2000 civic lx. Installed pioner H.U now interior lights dont work! Please help!!
- Opinions on these wheels
- 98 civic lx 200k miles yes or no?????
- Window Problems
- Strange rattling noise from engine when letting out clutch
- D16y8/d17 stroker
- unknown problem..??
- intallation help for AEM short ram on 98 civic lx
- Does anyone know how I can paint my brake calipers?
- tucking front wheels into fenders
- Need to know stock ride height of 98 civic
- hello to everyone
- Busted Gauge Needles
- My Introduction.
- Keyless Entry
- 01 Civic gauge Problem
- Suspension Noise
- "Under engine splash guard"
- 96-00 ex rear disc conversion?
- 01 automatic tranny problem
- Keyless Entry Problem
- pw steering
- 99-00 stereo surround/bezel - where to buy?
- pics of trunk struts needed
- small prob with my door latch
- my effin door latch
- i need to know something about a site before i drop cash
- Spoilers
- problem with ballast
- OEM (?) Tail light Issue
- Coilovers
- MOTOR BUILD. B16 or D16 turbo
- Abs
- just picked up my first honda
- Gold Rims and Tint
- keyless entry
- Engine failed to start and awkward noise heard
- 98 Civic sometimes won't start or stalls
- D16Y7 What will it fit in?
- D16y7 Head Change
- Location of the O2 sensor for a P0141
- Throttle Response gone ........................... :(
- Estimates...
- Where to find color matched side moldings/mirrors/handles?
- rimz ?
- effin B16a
- Tranny/Clutch Problem!
- Shift Knob/Shift Boot Fix
