engine oil dipstick tube
Old Dec 18, 2014
nep's Avatar
nep
nep is an unknown quantity at this point
So I bought a civic ex, 98, and it works great. One thing I found was that the oil dipstick tube was loose and moving around. At one point, I pulled it out entirely. The tube is still in good condition. But I wanted to know if anyone can give me advice on whether I should 1) get a new tube and install it, or 2) how to install mine so it doesn't move and come out. Because it comes out every time I check the oil.
Side note, is it ok if I put a new oil pan on the car without replacing the oil gasket? Mechanic said it would be better. Just wanted more opinions.
Thanks.
Old Dec 18, 2014
mikey1's Avatar
Re: engine oil dipstick tube
cant you just hold the tube in place while you pull the dipstick out?
Old Dec 18, 2014
mikey1's Avatar
im pretty sure that will leak.....very bad
replace the gasket, or at very least use some high temp silicone
Old Dec 18, 2014
nep's Avatar
nep
Yes but wouldn't you feel better if you knew everything under the hood is secured?
Old Dec 18, 2014
There's supposed to be a metal clip securing the tube to the lower timing cover.
Clip is #3 here
There is an O ring at the base of the dipstick tube
Part #19 here
Xuhme
21
Aug 7, 2023 03:40 PM
MyCivic
Electrical
Oct 28, 2021 11:06 PM
Grey
16
Jan 27, 2002 11:34 PM
supercivic01
South
Nov 30, 2001 11:27 AM
civiccowboy
Nov 19, 2001 03:44 PM
