A/C Clutch bearing replacement question 1998 Civic EX
Old Aug 26, 2015
Kenjitsu's Avatar
Kenjitsu is an unknown quantity at this point
So I was getting a lot of play and noise from the A/C compressor clutch pulley. I figured it was the bearing so I replaced it. When I put the pulley back on with the new bearing, there was still play in it.
Has anyone had this issue before? Any clues? Could the pulley nut not be tight enough to push seat the pulley even further?
I also noticed only 1 shim. In the replacement new clutches I've seen, I see they include three shims.
Any help would be appreciated.
Old Aug 27, 2015
Re: A/C Clutch bearing replacement question 1998 Civic EX
Play, in which direction?
I know it's difficult to see, but the snap rings for these are beveled on one side and designed to always push the coil and pulley to the fully seated position.
If you get either of them installed backwards it can allow unwanted movement.
The beveled edge should face you during install, the rings should seat into their grooves
(I twist a screwdriver around the edges to be sure it's seated).
Old Aug 28, 2015
Kenjitsu's Avatar
The play is in the whole pulley assembly...it wobbles even when seated..almost like there are not enough shims(if it takes more than one). Only one shim/washer was there when I took it apart toe replace the clutch bearing.
I'll check to see the orientation of the snap ring this weekend.
Thanks
Old Aug 28, 2015
What if the bearing wasn't actually the problem?
Remove the outer clutch plate, then watch in the hub area and figure out where the excess play actually originates?
EDIT: The shim(s) are only for adjusting the air gap between the pulley and clutch plate. They do not control any wobble in the pulley.
Old Aug 28, 2015
emich's Avatar
emich is an unknown quantity at this point
Same here. I had a cyclical noise I was sure it was the bearing so I replace it. The noise become worse. ezone is correct the puley with new bearing and new clutch should be replace together.
bsmiley
Apr 27, 2015 01:27 PM
vtechcivic
Apr 21, 2015 07:11 PM
dano2005
Apr 14, 2015 01:58 AM
thesushiboy
Apr 12, 2015 02:54 AM
Hrddrvs
Apr 11, 2015 11:22 PM
