SRS, CC, Horn Not Working - Already Replaced Cable Reel
Old Jul 1, 2015
cukaracha's Avatar
cukaracha will become famous soon enough
Hi all,
My SRS light stays on, and cruise control and horn don't work. I replaced the cable reel today, but nothing changed.
Also, the CC button on the dash (not steering wheel) doesn't light up when I press it (was like that before I replaced the cable reel). Also, when I switch the car on, the cruise control indicator in the instrument panel does not light up. I checked all the fuses and everything looks good.
Any thoughts?
Old Jul 1, 2015
Re: SRS, CC, Horn Not Working - Already Replaced Cable Reel
Originally Posted by cukaracha
Hi all,
Any thoughts?
What's the SRS code?
The horn is a relatively simple system, I'd grab a wire diagram and a voltmeter and see why it doesn't work
Cruise could be lots of stuff, start at the main switch and make sure it's IN after you push it. The light bulb for the green light may just be burned out, they do that a lot.
All brake lights work? No LED conversion brake lights?
Old Jul 2, 2015
CraigW's Avatar
Check the brake lights, share a fuse w/horn.
Listen for click from under dash when attempting horn.
Old Jul 3, 2015
cukaracha's Avatar
I double checked my work this morning and here are my findings:
The other end of the gray connector (horn and CC) wasn't connected (doh!!). But that was something the previous owner did.
Now the horn works fine. As for cruise control, the green indicator on the instrument panel lights up when I hit "Set" at desired speed.
Two issues:
1) SRS light stays on still. Previous owner had an aftermarket steering wheel without airbag, so I'm guessing that resetting the SRS will fix this? (Still trying to figure out how to do that).
2) Cruise Control does not hold speed. As mentioned earlier, the green indicator comes on as it should, but the speed just continues to drop. I did some A/C work previously, which involved moving the CC unit under the hood out of the way to access the receiver/drier. In doing so, I had to disconnect a rubber hose that attaches to the CC unit. Might be relevant information.
Any help is greatly appreciated.
UPDATE: Just reset the SRS, and the SRS light turns off. The only problem remaining is the Cruise Control not maintaining speed.
Old Jul 3, 2015
cukaracha's Avatar
UPDATE: Got the cruise control to work. Turns out one of the vacuum lines was disconnected (again, previous owner(s)' fault). Reconnected it and took her for a spin; cruise control works like a charm.
In summary, SRS light was fixed by resetting it. Horn and cruise control connector should be connected on both ends (live and learn....). Vacuum lines should all be connected on cruise control unit.
Thanks all!!
Old Jun 10, 2019
mkubancsek's Avatar
mkubancsek is an unknown quantity at this point
I am having the same series of issues that you are and I am considering a cable reel ("clock spring") replacement... how much work was that? Seems risky as I do not want to accidentally deploy the airbag. Any advice / guidance / link to instructions?
Old Jun 10, 2019
Colin42's Avatar
need to disconnect the battery and wait 15 mins, then work on removing the airbag
skj88
Electrical
Mar 30, 2025 06:31 PM
cukaracha
May 16, 2015 02:11 PM
SlyCayer
20
Apr 3, 2015 01:11 AM
usafstud
Mar 25, 2006 12:47 PM
namebrand
Jul 5, 2003 10:58 PM
