2002 Honda Civic EX Cruise Control
Old Mar 31, 2015
SlyCayer's Avatar
SlyCayer is an unknown quantity at this point
Hi guys,
The cruise control on my civic doesn't want to come on.
The green light is on on the main switch, when I press "SET" nothing happens.
Wondering if any of you might have an idea what it might be? I don't want to change the switches for nothing. Is there anything that could preventing it from engaging? Like Hood latch sensor or something like that?
Old Mar 31, 2015
Re: 2002 Honda Civic EX Cruise Control
The second light does not come on?
Got airbag warning light on? Does the horn work?
You can get a troubleshooting guide and a voltmeter and test each part of the system.
Old Mar 31, 2015
SlyCayer's Avatar
No airbag warning light, horn works perfectly.
troubleshooting guide? You know where I can find that?
Old Mar 31, 2015
SlyCayer's Avatar
The light in the dash doesn't come on.
The only light I have is the light on the cruise button on the right hand side of the steering wheel(with power mirrors panel).
Old Mar 31, 2015
Go to the last pages of this thread and see if the link is still up https://www.civicforums.com/forums/1...e-updated.html
I've never actually checked if it works or not .....
Old Apr 1, 2015
SlyCayer's Avatar
I would of hoped to have someone that had the same problem could lead me a little bit.
Old Apr 1, 2015
CraigW's Avatar
Do all the brake lights work ??.....and, brake lights are not LED retrofit ??
Schematic sent to email address.
Old Apr 1, 2015
SlyCayer's Avatar
Brake lights are new aftermarket LED housing. Could that be the problem? It would make sense, it stopped working after I did the install.
Old Apr 1, 2015
CraigW's Avatar
Problem solved......
Old Apr 1, 2015
SlyCayer's Avatar
What do you mean?
Old Apr 1, 2015
CraigW's Avatar
Sorry, no love here for available aftermarket led brake bulb replacements.
Factory systems......yes.
Add some load resistors if you choose.
Old Apr 1, 2015
SlyCayer's Avatar
So your saying even tho the Brake lights are not within the diagram they could be linked to the problem? How big do you think the resistors should be?
Old Apr 1, 2015
CraigW's Avatar
Proven fact, By you.
Not sure what value folks use. Check the online led suppliers and try to find a resistance value, and wattage they use. "load resistors"
They simulate the load of the missing bulbs filament
Old Apr 1, 2015
SlyCayer's Avatar
Could I buy extra sockets and just tap in the line with a new bulb?
Old Apr 1, 2015
This would have been handy info to include in the first post.....
Put your original tail/brake lights back in and see that your cruise works correctly again.
Old Apr 1, 2015
SlyCayer's Avatar
By looking at the wiring diagram which didn't mention anything about brake lights I didn't think it could have anything to do with it. Sorry.
Will do that first thing when I get home.
Old Apr 1, 2015
CraigW's Avatar
And keep them in place.....
Old Apr 2, 2015
SlyCayer's Avatar
No way! The tail lights are way too nice.
Old Apr 2, 2015
I used to say something similar about my ex-wife.
It took a while, but I learned.......
Old Apr 2, 2015
SlyCayer's Avatar
You're Crazy!
Old Apr 3, 2015
*DISCLAIMER: Not my picture. Shamelessly taken from a Google image search*
as stated above, load resistor will solve your woes. One across each LED brake light should do.
If the bulb in question acts as a double filament bulb (i.e. brake and turn signal), make sure the load resistor is across the brake light circuit, not the turn signal circuit.
jessicakaybby
Apr 20, 2015 12:11 PM
vino
Nov 3, 2001 11:08 PM
