- DIY Valve Adjustment Video
- Please help resonator question?
- What can I put into my 2005 Civic Coupe lx...Album on my profile
- Boh
- What can I put into my 2005 Civic Coupe lx...pic is to left
- Fog lights 04 coupe
- RIMs HELP!!!!!
- ft: 2001-2005 civic ex greddy exhaust
- Lights lights lights
- 2001 axel nuts WOT the !#@$%&^
- Maples back clean as F**CK EM2 Kpro panties wet!
- k swap sway bar question
- special edition wheels
- I wrecked my honda, need help finding parts.
- a free k20a2 instead of a a3
- Coolant Type
- o2 sensor question
- Over heating Help!!!!
- goodbye SI rims
- O2 sensors
- D16z6 tranny on a D17a2 engine?
- hesitation, cant go past 4k/rpm
- New Car, New member
- Ready to start with my 2001 ex coupe =)
- odometer is 888888
- looking for a UNIVERSAL Fuel Pressure Reg
- Catalytic converter
- Rev Limiter Help!?
- what do you think??
- Some quick cosmetic questions for someone that doesn't know jack.
- Buddy Club camber kit
- What Size Tires
- Help my clutch got jammed!?
- Ebay oem fog lights installed today
- My newer better rigged intake, injen and aem have nothing on this
- New; Located in San Diego.
- Will 04-05 tail lights work on a 02 2dr ex?
- Many Repairs Needed, Which Can I Do At Home?
- 2001 civic auto to manual swap. need help
- ATF change:drain or not?
- Lowering Sedan
- Pics of my new 2001 civic ex, RIP dode neon
- My ghetto rigged intake!
- Blew my head gasket and cracked the head
- Test pipe to stock exhaust
- Cast iron shield located in front?
- Eibach lowering springs
- Exhaust System?
- D17A1 turbo project questions
- swapping 02 tranny for 04 tranny civic
- A/C squeak
- EX vs SI Rims
- looking for a drivers side door. coupe
- For Sale 2004 Honda Civic LX
- 2'' drop, camber questions.
- I used non-honda power steering fluid? Am I screwed even if I get it changed?
- 02 civic ecu wiring diagram
- From (Vic)ky to (Merc)i
- Where to get fenders painted?
- im starting a poll lol
- New brakes/rotors
- Website suggestions please....
- swapped engine now need an opinion
- It's the little things...
- OVERHEATING!! Immediate Help please!!!
- ticket question..
- Want more power!!! What next?
- What engine do I have?
- Niew Owner of an 03 coupe LX need help
- Anybuddy...
- Where can I buy this special tool (In Canada)
- my first mods. intake/exhaust
- Night Hawk to Flat Black
- help on headers!!!!
- what muffler should i put on my 2003 lx ?
- What transmissions are compatible with 01 DX?
- what exaust tip should i put on my 2003 lx ?
- driver door lock problems
- Locked keys in car
- Lighting - What do you think?
- New front end struts for my honda =/
- Ep3 electrical issues
- Just became the proud owner of an 05 Coupe
- headlight switch clip
- Steering problem...help?
- General question
- Viper 5902 help..?
- Iat sensor
- Seat Swap
- Youtube record breaking d-series stock block d17a2
- Alternator/Overcharging - SES Light & O2 Sensor Issues
- tint or smoke kit.
- automatic transmission click
- Timing belt replacement?
- just getting my facts str8
- Gear position indicator panel
- How often does everyone change their ATF?
- Problem with blinker after LED install
- No clutch pressure
- k20 sawp in 01 civic sedan
- No Heat / DTC 8 / Air Mix Control Doesn't Operate Fully
- Overheating ?
- Canadian vs American DX
- 2DR and 4DR Side Mirrors...
- obd question
- New member w/ pics
- Skunk 2 lower control arms
- Rate my plugs!
- 2001 civic exhaust fitment
- 04-05 hood shield/ hood deflector
- New Civic owner
- maybe new headers
- no hub/grease seal on front wheels?
- Wont start
- will it fit????
- what's the best suspension for a 2002 civic?
- Have hi beams but no low beams
- Gauge cluster swap help
- Emblem painting!!! For my em2
- p1259 code
- whats the best exhaust for 2005 civic EX
- Highway RPM for manual.
- Competition Stage 1 Clutch
- I need Help
- New pics!!!
- Rough Shifting
- spoon lip for em2?????
- Need help w/ Valve Adjustment.
- header install
- Porting and polishing heads....
- MagnaFlow high flow catalytic converter
- sparkplugsource.com
- Engine Management on the low.
- were is that DIY ???
- EGR Passage Cleaning Help Please
- Member Journal: Lil Black 2002 LX Sedan
- 1st Post :) - Getting Started.
- anyone D17?
- 2004 Civic NEed help License lights!
- Contemplating a 01' EX
- Would you do it?
- Yup...HID Question Again...
- 2004 civic door speaker install w/ pics
- Sun+Carport= New Bumper
- I wish I had 5500 dollars... Nice RSX swap possibility.
- HID ground question.
- removing calk
- How do i install an Auxillary port?
- How much transmission fluid do I need?
- Noob. 05 Civic LX
- Aftermarket Headlights
- Car shut off..
- Seats Options
- Sway Bar Link
- Gear grind about 3 weeks ago, Clutch issue now, change tranny oil?
- please help me find
- Planning a midwest/chicagoland meetup!
- Help with exhaust
- Throwout bearing
- rims
- Engine light error- P0401 Insufficient EGR Flow
- Should I replace my rear O2 sensor?
- road noise
- Putting a 2004 transmission in a 2001
- Help with drop height..
- is anyone using this header
- 75 shot from a 10 mph roll!!!
- carbon creations front lip
- D17 turbo + internals- how much boost
- "Stutter" at 60km/hr
- Wide open wednesday at Miller Motorsport park!!!!
- Car Shakes on Acceleration
- 2004 Civic Si Engine won't Fire but turns Over Fine
- Question...
- Teen driver here...
- AIT Body Kit Quality?
- P0740 Torque Converter Clutch Circuit Malfunction
- Wisconsin people?
- Help me disable the alarm.
- 2001 Civic Suspension- FED UP!!!!!!!!!!
- Too many bells and whistles
- Looking for a diagram for replacing a front bumper pls help thanks
- 01 civic manual mods
- Manuals
- new car. new member.
- Em2 itb...post pics!!!!
- Need responces ASAP.
- rsx suspension on a 05 civic
- A quick question about catalytic converters.
- Cool air Intake?
- Questions About 2001 Civic EU1
- This is a tale story from a d17 and 5 b16
- I want it... What do you guys think?
- Horn issues pls assist thanks
- Which exaust should i get? Where would it be cheapest to get it from?
- Fuel pressure gauge install
- HELP Please! Broke valve adjustment screws
- Hey guys
- 2004 civic hx problem?
- 2005 civic oil question
- Reddd!!
- Shift Boot
- '04 hybrid- need new headlight housings- what to get?
- Fuel pressure
- cracked header
- Finally saved up :) ...lowering my ride :)
- FREE Shift Boot
- Mods for the beginning of the summer
- cost to change form automatic to manual transmission
- dechroming help
- d17a1 trying to boost
- Honda Civic Si 2002 $2000 to mod
- Decide for me
- 07 Fit HFP Wheels on EM2
- mufflers
- Aem ems
- magnaflow 2'25 muff
- how hard...
- Confused...:( ...quick decision...Reply asap guys ...opinion needed :)
- Driving lights, anyone?
- best strut bar
- Keyless Remote 2001 LX Coupe
- Strange Noise
- What else needs to be done at 110kmiles???
- How do you remove a JVC head deck and install an Kenwood deck into an 02 Ex
- What can it be???
- lightweight battery
- FG2 seats in EM2
- timing belt.
- Rear Door Panel Removal
- Keyless entry with K-pro?
- what is the best catalytic for 01 LX
- I need a stronger motor, the i wish thread...
- Header Cover Bolt
- DUDE.... seriously wtf?
- 2005 Honda Civic Upgrade Help!
- Couple new pics of the whip!!!
- Getting rid of the civic?
- Just bought a 2001 civic EX
- Valve cover gasket leak. Help please!!! (FIXED)
- need help URGENT
- p0141 Help
- 2002 Civic Ex with AT convert to MT ?
- Bumper changes on Gen 7 Sedans
- Do not use carstuffoutlet.com!!!!
- cleaning AEM dry flow.
- my new seibon hood!
- moisture in headlight
- interior moldings for 02 civic?
