No clutch pressure
Old May 27, 2010
Gold Ghost's Avatar
Gold Ghost has a spectacular aura aboutGold Ghost has a spectacular aura about
No clutch pressure
the other day i was driving an when i would start out at a light the clutch would go down but not come up. i was able to pull it up with my foot an it would work fine for a while. it did this randomly for 2 days then it went down an when i picked it up it just fell down. i have no pressure at all. i swaped the slave cylinder an bled the clutch. still no pressure. today i changed the clutch master cly an bled it. still no clutch pressure. i checked all the lines i cannot find a leak anywhere. the arm that comes out of the tranny an hooks to the slave isnt moving at all. im beatin myself over the head with this. just a fyi my car is a 01 civic ex coupe. i would b grateful for any ideas on this thanks guys
Old May 28, 2010
ondalow01's Avatar
ondalow01 has a spectacular aura aboutondalow01 has a spectacular aura about
Re: No clutch pressure
Damm dude.. idk, you've pretty much checked out what should of been the problem.. did you check the spring and things that are attached to your pedal, that would be my last thought on the clutch not engaging.. i know that my buddies car wouldn't go into gear before because his clutch disk had broken springs, but idk about your pedal problem. good luck.
Old May 28, 2010
BlueEM2's Avatar
Whachya lookin at?
Definitely a lack of pressure from somewhere. How are you bleeding the lines?
Old May 29, 2010
Gold Ghost's Avatar
yea i checked the spring but im gunna idiot check it again. when we did the slave we were pumpin the clutch an then my buddy got a rubber hose an was suckin the fluid through. talk bout friends! his *** was sick for 3 days. then when i did the master we pumped the pedal for 45 min. the fluid was comin outta the bleeder on the slave nicely. im gunna replace the clutch lines for ***** an giggles this week. my buddy said the fingers on the pressure plate could have popped out. or it could b the clutch pivot ball. the clutch an pressure plate have 1000 miles on em an are a competition clutch stage 2 kit. i never heard of anybody havein isssues wit them. i cant c it bein in the trans like he said cuz there is no pressure. even wit the pedal at the floor if i start the car i cant get it in gear. but not started it goes in fine. on a bright note i was offered a k20a3 long block for FREEE!!! the only catch is that i gotta drive to north carolina to my buddies marine base. thanks for the help guys
Old May 29, 2010
HLC's Avatar
HLC
HLC is an unknown quantity at this point
^^^ that scares me, i just installed my stage 2 comp clutch yesterday
Old May 29, 2010
a 10 hour drive isn't bad for a free k20a3.. Make a weekend trip out of it.. just sayin..
Old May 29, 2010
Crutcher's Avatar
Crutcher is an unknown quantity at this point
Try removing the slave from the tranny and bleeding it while holding the lines vertical. Hold the slave cyl up, that way any bubbles can make it to the top while you're bleeding. Had the same problem after putting in my stage 2 (But I disconnected my pressure lines -.-). Took me a month to figure it out after changing master and slave and all the lines, come to find out i just wasn't bleeding it right. FML. So hopefully you can learn from my mistakes :P
Old May 29, 2010
Gold Ghost's Avatar
wow i didnt no that holding the slave vertically could make a differance. thanks once i find a way to where my car is i will try that
Old May 29, 2010
BlueEM2's Avatar
Whachya lookin at?
I never had to do that when bleeding my clutch but anything is worth a shot at this point
Old May 29, 2010
Gold Ghost's Avatar
once again its raining here in the toilet of the country. i hate northeast pa. there goes my plans for fixin the civic today. anyway does anyone think that idea bout the clutch pivot ball or the fingers poppin outta the pressure plate?
Old May 29, 2010
Gold Ghost's Avatar
once again its raining here in the toilet of the country. i hate northeast pa. there goes my plans for fixin the civic today. anyway does anyone think that idea bout the clutch pivot ball or the fingers poppin outta the pressure plate could b a possibility. the guy who told me is a nissan guy so im hesitant to trust him lmao. disregared the post above this. my neice hit my key bored
Old Jun 7, 2010
Gold Ghost's Avatar
well heres small update. the vic has been in the shop since thursday afternoon. i spoke to the guy today an he said they r workin on it between jobs an have spent like an hr on it. they have zero clue y i have no pedal.
Old Jun 8, 2010
pjb3's Avatar
pjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of light
I have not taken a look at the slave cylinder on a Civic but I have seen other cars where it is possible to mount the cylinder upside down. If the line from the master cylinder is higher than the bleeder valve, there will be an air pocket. The bleeder valve should be at the top or highest point of the cylinder so all the air is removed.
Old Jun 8, 2010
Gold Ghost's Avatar
well its fixed they had to take the whole line apart an the salve an master an bench bleed it. im just glad to have it back
Old Jun 15, 2010
irish bugg's Avatar
irish bugg is an unknown quantity at this point
this has happened to me twice now its your clutch master cylinder against the firewall is blown out its like a $125 at autozone change that and your pivot ball a $5 part from your dealer you have to pull the trans to get to the ball. word of advice if you have the cheese is to change your clutch and throw out bearing as well that bad pivot ball cost be $2000 fried two masters and two throw outs and a stage 2 clutch! pm me if you have any other questions about em2's ive replaced everything on mine allready... oh wait not the seats there origanal!
Old Aug 8, 2010
D17cancun's Avatar
D17cancun is an unknown quantity at this point
So guys which was the solution for this issue???
Im having exactly the same and they have my car on the hondae dealer
plese post me or send a pm
Old Aug 8, 2010
That's why I posted "you have to bench bleed the slave and master cylinders thoroughly" in your thread..
Old Aug 8, 2010
D17cancun's Avatar
Originally Posted by xriceboyx
that's why i posted "you have to bench bleed the slave and master cylinders thoroughly" in your thread. But i guess my input doesn't mean ****..
sorry man
im working alot of work so i dont read well hahahaha
and my english is not workin
my bad riceboy
but anyway ill will tel this tips to the guys on the dealer
mrohitredd
40
Sep 9, 2017 12:03 PM
mjdiaz89
Jun 21, 2016 09:26 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
adamdrives
15
Aug 8, 2015 08:53 PM
Mike_47
Transmission
Jul 8, 2015 02:42 PM
