k swap sway bar question
Old Jul 10, 2010
Gold Ghost's Avatar
Gold Ghost has a spectacular aura aboutGold Ghost has a spectacular aura about
i just read through a thread that xxriceboyxx posted in regards to a k swap. one thing that wasnt mentioned was sway bars. it stated that u need a sub frame from a 02 -05 si or a rsx. my question is will my 01 civic ex eibach sway bar bolt up to the sub frame? anybody have any experience wit this swap? btw i have a 01 civic ex 2 dr 5 spd
Old Jul 10, 2010
HLC's Avatar
HLC
HLC is an unknown quantity at this point
Re: k swap sway bar question
the sway bars bolt to the knuckles i believe.
Old Jul 11, 2010
Gold Ghost's Avatar
i could b wrong b i swear mine connected to the sub frame
Old Jul 11, 2010
HLC's Avatar
HLC
well, considering we can directly swap rsx sway bars. im pretty sure either will work with a kswap.
Old Jul 11, 2010
02civicsi02's Avatar
Low and slow!
Your stock sway bar should fit just fine. The end of the sway bar is hooked to the endlinks which are hooked to the knuckle. Towards the middle of the sway bar they are bolted to the subframe. Your sway bar should work out fine but not to sure bout the clearance of the header. You might have to use the ep3/rsx sway bar not to sure.
Old Jul 27, 2010
weren't the endlinks bolted to the LCA?
Old Jul 28, 2010
03civicexR's Avatar
03civicexR is an unknown quantity at this point
actually if u read the forums on clubrsx they always say to use a em2 sway bar when putting any sort of race header on a rsx or ep3, so i dont see why it wouldnt work
Old Jul 28, 2010
Low and slow!
Thats actually mainly for k24 swaps in the ep3 or dc5. The reason is because of the k24 sits different and with some headers it will not clear the original sway bar thus having to either go without one or changing to the em2 sway.
mrohitredd
Jun 9, 2015 06:37 AM
Rogelio Rey
May 24, 2015 08:30 PM
Dorval Andre
May 1, 2015 09:37 AM
bsmiley
Apr 27, 2015 01:27 PM
jessepimpride
Nov 13, 2001 05:59 PM
