just getting my facts str8
Hey guys haven't been on for a while now. Been having issues with the car. Got the famous head gasket problem and more. I been jumping from forum to forum and it gets annoying how ever body keeps getting on our generation. But all I keep seeing is go k or go home and so far I seen an h series. That's a whole lot better then our d series. But seeing I don't have k money should I just go h or do a different swap. Or fix it lol help a fellow bro
Re: just getting my facts str8
7Th gen H swap is a nightmare. There is no support for it whatsoever. I'm sure it's been done but I doubt you will find help in doing it. You'd have to custom fab mounts and everything. It will probably in the end cost you just as much as a K swap just because of all the custom work required. I say fix your D series and keep driving it
It may not be a fast engine but it's still a good one.
It may not be a fast engine but it's still a good one. Re: just getting my facts str8
lol thanks i just needed some help into what i should do was looking at other series just so i can get an idea but now my issue is my car overheated so im hoping the block didnt melt in heard like a clink noise or like something dropping when i gased it so i parked the car and it didnt start so a couple days later it did so right now im hearing my issue is the head gasket if anyone knows help me out thanks
So it still overheats after you changed the fan switch, flushed the rad, and changed the thermostat? Do your fans turn on at all? With the car running turn your AC on and see if the fans come on. With the car cold, open the rad cap and check to see if there is coolant up to the top.
check your oil. If it looks like a milkshake, then you got coolant leaking into your oil --> blown HG
Like everyone said it was the head gasket but the oil wasnt milk shake except in the radiator even though there is another trick to see your gasket blew if it bubbles thro the radiator
Yea bubbles in the coolant is a good way to check. There is also a method where you actually test those bubbles to see if its air getting in or exhaust. It's a pretty neat test. When my head gasket blew I had no white smoke coming out of the exhaust, no white on the rad cap, and the car ran like brand new still.
2002ExCivic
22
Sep 28, 2015 08:29 AM
SolidHollow
15
Sep 13, 2015 11:18 AM
0396
Aug 21, 2015 05:27 PM
