looking for a UNIVERSAL Fuel Pressure Reg
Old Jul 5, 2010
em2allday's Avatar
em2allday is an unknown quantity at this point
I am about to boost my em2 and I need one.. What a good name brand. Wear can I find one.
Old Jul 5, 2010
HLC's Avatar
HLC
HLC is an unknown quantity at this point
Re: looking for a UNIVERSAL Fuel Pressure Reg
aeromotive. i assume you are doing a fuel return conversion?
Old Jul 5, 2010
em2allday's Avatar
I'm bout to run boost n I need it to get more fuel inless u kno where I can get a adjustable regulater for tha d17 mani n idk if u can take off tha stock one
Old Jul 5, 2010
depending on how much boost you're planning on running, getting a walbro 255LPH pump and high flowrate injectors will make do..
edit: wait.. how much research have you done before you decided you're going to boost it?
Old Jul 5, 2010
HLC's Avatar
HLC
yea...if you're expecting to be able to adjust fuel pressure, you must to a fuel return conversion.
Old Jul 5, 2010
em2allday's Avatar
wear can i get a Fuel Pressure Reg from and one of my friends say get a boost sensative on wear can i find one of them too and how much..i want to run like 5 to 8 psi
Old Jul 5, 2010
If you want to be able to utilize the FPR, you need a return style fuel conversion. Otherwise, it'll be useless to you. With 5-8 psi, you can get away with the pump and probably RSX-S injectors. Not so sure on the injector part, though.
Old Jul 5, 2010
em2allday's Avatar
so do nt get a fpr.. just get a walbro 255 and bigger injectors and i run good..
Old Jul 5, 2010
There's a lot of members here not even running the walbro 255lph pump, just bigger injectors.. When I was boosted (although only 2.5psi due to a wastegate actuator problem), I just installed some RSX-S injectors and was more than fine.. As long as you can tune it properly, you should be fine.. assuming the injectors are enough for the boost level you want.
But seriously, how much research have you done before deciding to go turbo? That was a serious question.
Old Jul 5, 2010
em2allday's Avatar
alil.. too of my friends got boost cars and they got fpr's and stock injectors and that **** run great
Old Jul 5, 2010
You might want to do a LOT more research so you don't end up spending a **** ton more money fixing stuff. Trust me, I've spent at least $4000 on my car in boost equipment alone, and that boost setup lasted all of a year and a half.
And your friends' cars obviously aren't d17 Hondas, are they? Engines, especially the d17 vs older d- and b- series engines, behave a LOT differently than other engines do.
Old Jul 5, 2010
em2allday's Avatar
they got d15 motors...i got a ebay turbo kit brand new.idk y everbody tellin me to get a fpr i am goin to get on no matter just to be safe.just got my oil pan done today...do u no any website wear my can get parts of the d17
Old Jul 5, 2010
HLC's Avatar
HLC
also, learn how to spell and have good sentence structure. it's tough to read when utlk liek dis yo. mad jdm tyte!
btw, YOU CANT USE A FUEL PRESSURE REGULATOR UNLESS YOU DO A FUEL RETURN SYSTEM CONVERSION!!!!
Old Jul 5, 2010
em2allday's Avatar
my bad i text alot
Old Jul 5, 2010
I'm gonna stop contributing to this thread. You apparently don't listen to **** anyone says. I just said a D17 behaves differently to even previous D-series engines.
/thread. I hope you blow your fu*king engine up.
Old Jul 5, 2010
em2allday's Avatar
thanks alot
Old Jul 5, 2010
HLC's Avatar
HLC
the d17 has a returnless fuel system, the fuel pressure is maintained by a spring somewhere near the fuel pump assembly inside the gas tank. due to the returnless nature, even if you try to add more pressure to the fuel, nothing will happen. the only way to correctly utilize a fuel pressure regulator, such as the aeromotive a1000, is to modify the returnless fuel system into a return fuel system. meaning excess fuel is sent back to the fuel tank instead of the system the stock fuel system uses.
the aftermarket fuel pressure regulator you're looking to buy can create a rising rate fuel pressure so that for every pound of boost you run, the regulator automatically adds one pound of fuel pressure.
without doing the fuel return conversion, you are wasting your money by buying the fuel pressure regulator.
i dont think i can be any clearer than that. i'm done.
Old Jul 5, 2010
BlueEM2's Avatar
Whachya lookin at?
So, I don't really need a fuel return conversion if I only boost 8lbs right?
lol, sorry.. had to
Old Jul 5, 2010
em2allday's Avatar
thanks alot hlc. so what do u recommend me to do to make it run good for the street
Old Jul 5, 2010
HLC's Avatar
HLC
lol, in terms of fuel delivery? adequately sized injectors, kpro.
Old Jul 5, 2010
em2allday's Avatar
what a good size to go wit motor stock
Old Jul 7, 2010
04 Honda Civic's Avatar
I say sell the ebay kit and save up for a better kit. I believe it will be worth it in the long run. Also doing some more research, and realising how much this is really going to cost you in both time and money. By the posts in this thread I dont think you are ready to boost your car just yet.
Old Jul 9, 2010
Gold Ghost's Avatar
Gold Ghost has a spectacular aura aboutGold Ghost has a spectacular aura about
i wont go as far as riceboy did though i agree wit him. u need to research an plan for boost. ebay kits equal blown motors. if they boost at all. my buddy got one for his tc an the turbo was seized. 800 clams down the drain. b 4 u boost look into it. u have a choice. do it half *** now an spend a bit of cash and end up spending a mountian of money to fix a blown motor or do it rite the first time .
Old Jul 17, 2010
mr22508's Avatar
Pistol grip pump in my lap at all times
mr22508 is a jewel in the roughmr22508 is a jewel in the roughmr22508 is a jewel in the rough
DUDE!!! DO NOT BOOST your car!!!! You are definetly not ready! And if your friends knew anything about Hondas they would tell you the same! They must be Mustang owners. Anyway, there is alot of basic stuff that you need to know about our year, make and model of car. Honda went above and beyond to make sure the EM2 was completely different from all the Civics before. Research man, its not hard, and it will keep you from going out and looking dumb at the track when your engine blows pushing 8 psi!!!
Old Jul 17, 2010
HLC's Avatar
HLC
mjdiaz89
Jun 21, 2016 09:26 PM
LorenzoC0395
Jul 14, 2015 08:46 PM
mistermenphis22
Jul 13, 2015 04:43 PM
