How much transmission fluid do I need?
Old Apr 30, 2010
onlycodered's Avatar
onlycodered is an unknown quantity at this point
Hey all. I have a 2002 Civic EX (MT) and I'd like to replace the transmission fluid since I think it's been a while since that was done. Does anyone happen to know how many quarts I need?
I couldn't find anything in my owners manual. Any help is greatly appreciated!
Old Apr 30, 2010
hattori's Avatar
hattori is an unknown quantity at this point
Re: How much transmission fluid do I need?
there must be scale on dipstick. Be sure you park your car on flat surface
Old May 11, 2010
AUS-ES1's Avatar
AUS-ES1 is an unknown quantity at this point
i believe it is approximately 1.6L.
Old May 11, 2010
seoul4korea's Avatar
seoul4korea can only hope to improve
MMMM not sure for civics. I'd check the dip stick like he said. For supras theres a drain bolt and a fill bolt. You fill it up till it trickles out the side of the fill bolt and close her up.
Old May 11, 2010
Keepitmovin's Avatar
Keepitmovin is an unknown quantity at this point
Auto's have a dipstick but not MT. AUS-ES1 is right- appx 1.6L. Its just drain and fill- follow the diy's on the site. Best advice I found when I did mine was crack the fill plug first before the drain plug in case u drain the fluid then find out the fill plug is jacked, and make sure u keep the car level.
Old May 24, 2010
HondaRKing's Avatar
HondaRKing is an unknown quantity at this point
Its like 2 and a half quarts you cant over fill the manual just fill it until it comes out and your good. But i will suggest you get the factory honda fluid. We have had cars come in with trans noises from having it changed with other companies fluid
Old May 25, 2010
Tappz's Avatar
Tappz is an unknown quantity at this point
i just did mine the other day, mine took 1.6L with a little over fill drainage
OptimisticWay
46
Oct 15, 2015 02:16 PM
AirJordan613
General 7th Gen
Aug 2, 2015 08:55 PM
Q-Bert
Jul 19, 2015 09:09 PM
srtlat
Jul 17, 2015 11:53 PM
Jul 12, 2015 11:54 AM
