Member Journal: Lil Black 2002 LX Sedan
Rep Power: 0 Member Journal: Lil Black 2002 LX Sedan
So I'm going to leave this thread open for everything I'm going to do to my 2002 Civic LX Sedan. I'll list plans and post pics of everything that I do to her. Very Open to anything you guys have to say, questions, comments, and suggestions. Here are the lists:
Maintenance List:
Fix Moisture In left headlight
Fix haze in both Headlights
Re-do "Big 3" ground wiring
Replace all filters
Do my own oil change
Do all fluids
Exterior/Interior List:
Replace door panel cloth
Paint Chrome (trunk and hood emblems, trunk and hood molding) Black
Fog Lights
Tint
Entertainment List:
Small Sub
AMP
Replace old aftermarket headunit with Pioneer DEH-6000UB
New speakers
Maintenance List:
Replace all filters
Do all fluids
Fog Lights
Tint
Entertainment List:
Small Sub
AMP
New speakers
Rep Power: 0 Re: Member Journal: Lil Black 2002 LX Sedan
The Maintenance Required light blinks and beeps when I turn the car on....oil insn't due for another 200+ miles...any ideas?
Rep Power: 239 Re: Member Journal: Lil Black 2002 LX Sedan
hold the trip reset button on the cluster, turn the key to II position(III is engine on) wait about 15-30 sec for it to clear..this info can also be found in your owners manual
no i mean i've read about how to turn it off, but i was jsut wondering if there was anything I was suppose to do at almost 97,000 miles
Whachya lookin at?
Rep Power: 289 Re: Member Journal: Lil Black 2002 LX Sedan
Your Honda Owners Manual has a great service schedule in it that will tell you what your supposed to do at certain intervals. I'm far too lazy to go outside and get mine!
Whachya lookin at?
This is for 160, 000 kms which is pretty close to 97k, what's not mentioned here is that 100k(miles) is timing belt time.
Check all fluid levels, condition of fluids, and check for leaks.
Check all lights.
Inspect brake hoses and lines (including ABS).
Inspect cooling system hoses and connections.
Inspect driveshaft boots.
Inspect exhaust system.
Inspect fuel lines and connections.
Inspect parking brake adjustments.
Inspect suspension components.
Inspect the underbody.
Inspect tie rod ends, steering gear box and boots.
Lubricate all hinges, locks, and latches with multipurpose grease.
Replace engine oil* and filter.
Rotate tires**, inspect for wear and adjust pressure.
Service front and rear brakes.
Check all lights.
CarStuff
12-06-2020 12:52 PM
