- immobilizer not recognizing key after removing tumbler
- SRS light came off
- 2003 Honda Civic EX immobilizer issues.
- Yet another Immobilizer thread
- Driver's Seat Buckle
- 2003 Honda Civic ex immobilizer issues
- 04 civic si seat belt buckle explosive device [solved]
- Lost key has become a huge problem [solved]
- parts shortage-long wait time in repair shop [solved]
- Keyless Entry, Tried Everything I Could Find
- SRS code 4-1. My seat belt reads around 6ohm. Should be 2-3ohm, right?
- 2003 Civic EX immobilizer help
- Is this a transponder key(key with a chip)
- Want new replica chip key
- Where to get duplicate master key?
- SRS permanently on ….2001 civic executive
- 02 civic bypass anti theft ?????
- '05 VP green key light problem/every other start
- Cold immobilizer causes no start
- 2001 Honda Civic won't start, Green Key flashing
- Ignition key doesn't turn bad tumbler [solved]
- Green key flashing
- Help Identifying SRS Codes
- 2003 anti theft / immobilizer problem
- Unlock doors by 'hotwire'
- Air bag light won’t go out
- ex swap
- SRS 4-1 electrical vs. Mechanical
- This might be a sketchy conversation
- Intermittent SRS light. Dealership replaced belt buckle four times already. 02CivicEx
- Airbag light on? [solved]
- ECU swaps possible?
- 02 civic immobilizer
- 2002 won't start
- Car Alarm
- car won't start after ignition cylinder repair
- 2003 Civic EX - Door Lock Cyclinder Swap?
- How to find fcc id #
- SRS codes
- Honda civic 2003 abs/airbag code
- non working remote -- solved.
- K20
- Help - Tried programming the key fob I'd never used, now alarm keeps coming on.
- 2001 Honda Civic LX
- Need correct Immobilizer tool for 2005 civic
- 02 EX Coupe - SRS Light - 9-3
- Ignition key and door key are different
- D17A2 harness help - NO START
- SRS Code 9-3
- 2004 Green flashing light after head gasket.
- srs light on all the time
- I don’t know what to do. Help
- SRS code 09-02
- What is this and what does it do?
- Keys replacement
- Ignition problem?
- New to Civic - new to forum! Hello All
- Srs lamp on
- Replacement Ignition Lock Cylinder not working, cant program key
- 2002 Civic SRS lights
- Remote start bypass module help
- Air bag light won’t come on
- Ecu swap out issues
- Strange Immobilizer Situation
- Airbag replacement at home from Honda
- I have never seen anything like this - has anyone else ?
- 02 civic immobilizer removal?
- 2004 Honda LX Sedan with air bag code 2-1
- SRS Light - Where to begin?
- Airbag light 2 weeks after dealership replaces airbag
- Ignition Switch Help please
- SRS Code 7-2 Internal Failure
- ecu swap
- SRS on, no error?
- Wireless Key FOB
- SRS code 2-1
- Seatbelt Buckle Issues
- srs brain swap?
- SRS Light On, Code 9-3, Need Advice Please
- 03 Honda Civic lx 4door. Key is stuck in the ignition [retumbling key instructions]
- Key won't unlock driver side door
- 2002 Civic - weight sensor in pass. seat rail?
- Needed: Pair of keys for 03 Civic
- how to get key copies
- Lost both keys
- Seatbelt / SRS light question
- Green Key Light Blinking - Car Shuts Down While Driving
- Airbag light on AFTER recall repair
- 2002 Immobilizer - bypass - remove
- 2002 civic immobilizer and angry boyfreind
- Airbag light came on, no fault codes reported
- i need s ome help with my immobilizer
- SRS Light
- programming key fob flashing green key light
- Need New Key Cut + Programmed -Help!
- 7th gen transponder key types
- Intermittent Flashing of Airbag, Seat belt, and Battery Indicator Lights
- Does 2003 Civic Lx Model come with factory fitted Keyless Remote
- Green key light flashing
- Need help about my keyless entry remote
- Car won't release key from ignition. HELP
- Keyless entry NOT working.. help!!
- Side airbag off light comes on randomly
- How much are 2001 civic keys?
- Pass side seatbelt locked
- Dead battery, need to reset immobilizer?
- Keyless Entry Gone Crazy...
- Remote lock/unlock problem
- Honda Key's
- Air bag light on
- SRS light on, NO WARRANTY
- immobilizer woes
- Side airbag light on/off frequently
- Air bag light
- SRS light
- SRS Problem pinpointed
- srs light is always on no matter how
- Driver's side seatbelt part rattle! HELP!
- how much for a replacement key?
- SRS Airbag Light
- WHO'S SRS LIGHT KEEPS COMING ON?????????????????????
