Safety/Security Items - SRS, Keys, Immobilizer, airbags, ABS Post your safety, security questions here! Airbags, Keys (immobilizer)
SRS Light - Where to begin?
Old Sep 17, 2018
mikey1's Avatar
My SRS light came on for the first time ever yesterday in my 05.....just wondering what the first steps that should be taken?
Old Sep 17, 2018
Re: SRS Light - Where to begin?
Old Sep 17, 2018
Read codes man!
Old Sep 17, 2018
mikey1's Avatar
oh....i wasn't aware SRS set different codes
Old Sep 17, 2018
What do you mean by "different"?
The SRS system has its own complete set of unique fault codes.
Old Sep 17, 2018
mikey1's Avatar
i didn't know it set different codes for different problems within the SRS system,
i thought the SRS light was kind of like your oil light and meant only one thing,
i wil get the codes read,
i disconnected the battery overnight to try to reset it, and the light is still on
Old Sep 17, 2018
You can read and erase srs codes diy, search for how tos?
Old Sep 17, 2018
mikey1's Avatar
oh....so they are not read the same way as CEL codes?
im reading ways to reset the light from under the dash at the yellow wire connector?
will disconnecting the battery reset the SRS light?? like it will the CEL??
Old Sep 17, 2018
BrotatoChip's Avatar
Super Moderator
You should try searching. There is a sticky in the same section of the forum you posted this.
https://www.civicforums.com/forums/3...srs-codes.html
Old Sep 17, 2018
DIY: SRS Codes and reading them
DIY: Reset SRS Airbag light (With Video)
Old Sep 17, 2018
Only if you have a scanner that can read SRS codes.
Otherwise, follow the links everyone else posted.
Not normally, but in some cases the light may go out on its own after a fault is corrected. Codes may be stored in memory even after the warning light is off.
Old Sep 20, 2018
Alfie17's Avatar
Alfie17 is an unknown quantity at this point
Check to see if your car has a recall. My SRS light came on last year in my 05 civic and it was a recall with some sensor in the seat belt.
jonnymorrow
Electronics
Jul 24, 2019 10:49 PM
crazyone64
Sep 14, 2018 07:54 PM
Nycmedic
18
Apr 30, 2016 05:05 PM
threeoten
Jul 26, 2012 09:12 PM
bdahlg
Sep 27, 2010 04:28 PM
