Srs light diagnose helllllppppp.
Old Apr 22, 2016
Nycmedic's Avatar
Nycmedic is an unknown quantity at this point
Hi, 1998 civic lx, have a srs light that came on while I took my seatbelt on hwy. just purchased vehicle, only had for 2 weeks. The seatbelt light doesnt come on when seatbelt off, I'd have to play with buckle in order to come on. Probably obvious this may be the cause of the light but I'd like to make sure, so my question is how do you check srs light without scanner?
Thanks
Old Apr 22, 2016
Re: Srs light diagnose helllllppppp.
Look up how to read flash codes by jumpering the SCS connector
Old Apr 22, 2016
Nycmedic's Avatar
Everyone I see is showing me how to look up abs or check engine. Which I need SRS. I have no check engine nor abs.
Old Apr 22, 2016
Use the same procedure to read SRS codes.
Old Apr 22, 2016
Reverb2005's Avatar
Reverb2005 is a glorious beacon of lightReverb2005 is a glorious beacon of lightReverb2005 is a glorious beacon of lightReverb2005 is a glorious beacon of lightReverb2005 is a glorious beacon of lightReverb2005 is a glorious beacon of light
READ:
https://www.civicforums.com/forums/1...ding-them.html
And search before posting. Almost every problem has already been posted and discussed/solved for 6th Gens at this point....
Old Apr 22, 2016
Nycmedic's Avatar
Does that work on 98? Everyone that posts has a 01 and up ! I'm not trying to screw up my engine fuse and what not. I've done research and cannot find anything pertaining to 98 civics. The only thing I see is people resetting the srs light not actually reading the code.
Old Apr 22, 2016
On a 98 car you cannot use the OBD2 connector unless you are using a real scanner.
You have to jumper the SCS connector to get flash codes.
Old Apr 22, 2016
TS2008's Avatar
TS2008 is an unknown quantity at this point
Go buy yourself a cheap Bluetooth OBDII code reader like this one.
Amazon.com: Veepeak Mini Bluetooth OBD2 OBDII Scan Tool Scanner Adapter Check Engine Light Diagnostic Code Reader for Android Windows: Automotive Amazon.com: Veepeak Mini Bluetooth OBD2 OBDII Scan Tool Scanner Adapter Check Engine Light Diagnostic Code Reader for Android Windows: Automotive
I have one and it works great. I use torque pro and this application analyse the codes and it gives also ton of live info about your car.
I can't tell if torque pro will analyse the SRS code as well, but for that price, you have nothing to lose.
Old Apr 22, 2016
OBD2 deals only with powertrain: engine and transmission.
Unless a device specifically states it will read ABS or SRS or any other system you need to access and it states it will do it on the car you have, don't expect it to.
Bur yeah that's dirt cheap for getting engine codes LOL
Old Apr 22, 2016
TS2008's Avatar
I was at first skeptical as well because the cheap price. But there are so many positive reviews that I said to myself why don't you give this gadget a try and the worst case scenario for me will be wasting 15 bucks. For having played with this gadget, I have to admit that I was agreeability surprised. This gadget can read not only error code but it gives also sensor data like rpm, air intake temperature and coolant temperature, engine load, intake vacuum, throttle position and more. I said OP should give this gadget a try because it seems the SRS signal wires are also connected to the obd2 port.
Old Apr 23, 2016
Nycmedic's Avatar
Is this gadget only for android ?
Old Apr 23, 2016
TS2008's Avatar
Mine come with a software for PC and Laptop. But I prefer Torque pro (android) because is more practical to use a smartphone or a tablet for monitoring the sensors.
Old Apr 23, 2016
I did not see any mention of SRS capability in the descriptions.
Old Apr 23, 2016
TS2008's Avatar
You're right. I did a search with "SRS" as keyword from the reviewer's comments and they stated that the gadget won't read SRS nor ABS codes.
Old Apr 28, 2016
Nycmedic's Avatar
Thanks a lot ezone. I was able to pull code. Getting 1-1. I believe thats "open or increased resistance driver airbag". How do I fix this? Can I just replace the airbag or there's more to it ? As per carfax, car has been in an accident but it doesn't say airbags deployed. I tried resetting light but it comes back on.
Old Apr 28, 2016
Nycmedic's Avatar
Old Apr 28, 2016
1-1: Open
1-2: high resistance
1-3 short circuit or low resistance
Could be anything in the circuit between the control unit and the drivers airbag....
Unplug airbag then reconnect it a few times, erase codes, see if code returns
Unplug airbag, insert 2 ohm resistor in car side connector terminals, see if code goes away (simulate correct airbag resistance for testing)
Unplug airbag, bridge terminals in the car side connection, see if code changes to indicate short circuit (code 1-3)
If no joy, go to step B
Step B: Go to clockspring (cable reel) connector under column and repeat above tests using the car side connector
Ohm test clockspring circuits
CLUE Does anything else controlled on the steering wheel not work correctly?
Do not ohm test the airbag unit itself, if your meter is not right you could trigger an explosion
No time to explain much more about this right now
Old Apr 30, 2016
Nycmedic's Avatar
1-1: Open
Thanks.
The cruise control doesn't seem to work. But the horns do. Those are the only 2 functions on them at steering wheel. I will have to pick u a 2 ohm resistor and check things out. What can be wrong if the cruise control doesn't work ?
Old Apr 30, 2016
Did you bridge the terminals of the airbag connection (maybe with a paper clip or bare bread tie wire) to see if the control unit recognizes a short and sets the appropriate code?
2 ohm resistor may not be necessary.
I mostly use that if I believe the airbag may truly be at fault. I can deduce the rest of the systems circuit by verifying if it will or won't set the correct codes for open or short circuit from the various connectors.
I'd go to the dashboard harness side of the clockspring connector (underside of the steering column, usually a bright yellow connector shell, wire colors could be gray or green) and bridge the terminals to short the airbag wires, see if the SRS control unit recognizes the short and sets the appropriate code for a short circuit.
If it will, then I'd ohm check the individual circuits of the clockspring, it may be partially broken inside.
91EF
Apr 28, 2016 09:29 PM
amctom
Apr 6, 2016 09:33 PM
jwatson741
Apr 2, 2016 08:14 PM
trellex
Mar 28, 2016 07:02 PM
beeson76
Mar 27, 2016 08:19 PM
