Safety/Security Items - SRS, Keys, Immobilizer, airbags, ABS Post your safety, security questions here! Airbags, Keys (immobilizer)
Airbag light on? [solved]
Old Oct 19, 2021
2005-civic-vp's Avatar
2005-civic-vp is an unknown quantity at this point
The airbag light stays on all the time. Is there a sensor in the seat that's supposed to detect when someone's sitting in it? Maybe mines broken?
Old Oct 19, 2021
re: Airbag light on? [solved]
check what code you have
Old Oct 19, 2021
wait, are you talking about the light on the dash or the one in the center console?
Old Oct 19, 2021
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
Bet it is the SRS 9-3 code for a faulty driver's seat belt buckle switch - common issue.
Old Oct 19, 2021
FRSam's Avatar
Click Here
Check for an airbag recall. There have been a few over the years which could also be your problem.
Old Oct 19, 2021
DIY instructions to check your question
  1. turn the engine on.
  2. Keep it parked.
  3. Open the door
  4. get out of the car
  5. walk to the passenger side
  6. open the door
  7. sit on the passenger seat
  8. check if light is still on.
Old Oct 19, 2021
I second this only fix is replacement then clear the code
Old Oct 19, 2021
I just cleared it using a paper clip after watching this video. Bought the car a year ago and this is the first time I got the light off. No more black tape on instrument cluster to hide the annoying light lol!
Old Oct 20, 2021
BrotatoChip's Avatar
Super Moderator
Re: Airbag light on? [solved]
Now the question is will it come back?
Old Oct 21, 2021
I will update soon
Old Oct 24, 2021
Update: After 2 days driving 300 miles the light has stayed off. Clearing the light also made the red blinking security light on radio work for the first time since I had the car.
Old Oct 24, 2021
lol you lucked out. There's a procedure of how to read SRS codes. I know I updated it at some point. It'd be worth having in your troubleshooting arsenal
edit: here's a link for my post about reading SRS codes
https://www.civicforums.com/forums/3...ml#post4768801
Old Oct 24, 2021
FRSam's Avatar
Click Here
Good to see the issue was resolved. It still may be worth checking for active recalls with the Takata airbags.
Old Oct 31, 2021
Just checked and no recalls on my civic
Old Dec 1, 2021
Lenny D's Avatar
Lenny D is an unknown quantity at this point
Maybe not.
My '03 civic SRS light came on and with code 9-3. Searching produced this vid that describes how the little pin inside the buckle doesn't work properly anymore, probably because of dirt and grime.
I followed the vid to open the buckle with a T10. Front and back of case have to come off. The little red "boot" that surrounds the pin prevents (so the vid says) contact cleaner from getting in. I really didn't want to destroy that boot so manipulated the pin WHILE spraying cleaner. Many many times.
Then I did the paper clip trick to reset the light. Started the car and poof--light stays off.
Now, I just did that so I don't know: I might have to go in again and this time, remove that boot. Time will tell.
This vid is exactly how I did the (temporary?) fix.
Old Dec 2, 2021
Super Moderator
I did a similar cleaning of my driver buckle probably like 8-9 years ago, still working to this day.
Old Dec 2, 2021
FRSam's Avatar
Click Here
Mine worked for about 4 years until the light came back on for the passenger side deflator failure, causing the code to permanently return. Can’t say for certain if 9-3 ever came back or not because I never fixed the deflator.
Old Dec 19, 2022
Lenny D's Avatar
Been a year since I cleaned the "button" and reset with the paper clip and the light is still off. The buckle is pretty difficult to release when exiting the car but that is a diff issue.
shmo
General 8th & 9th Gen
Apr 24, 2021 08:42 AM
saves
Aug 22, 2018 12:02 AM
nunzio42
Jun 5, 2006 01:05 PM
vincenzobar
19
Jun 28, 2003 07:33 PM
DriftR
Feb 21, 2002 08:18 AM
