Safety/Security Items - SRS, Keys, Immobilizer, airbags, ABS Post your safety, security questions here! Airbags, Keys (immobilizer)
srs light on all the time
Old Nov 9, 2019
noquacks's Avatar
noquacks is an unknown quantity at this point
People,
SR light has been on for a while. I tried to do the reset with the paper clip, but it did not work, meaning the light is still on. So I bought a module from ebay. Popped it in and same thimng- srs light is still on. Supplier said it didnt come from a crashed car. I am returning it.
So now, what would you do? Send my module to a place that specializes in resetting it? Anything else for me to look at? Retrieving codes? Could go to local jun yard and pull another one. Just some time.
Thanks.
Old Nov 9, 2019
Re: srs light on all the time
$20 says it's the driver's side seatbelt buckle.
Pull the code to be sure. Here's how to do it (source: DIY: SRS Codes and reading them. I consolidated all the steps from the CRSX link within and stuff here for ease of reading. All credit goes to user R3dline on ClubRSX)
How it do: (READ THE ENTIRE THING BEFORE PERFORMING. It'll help. I promise)
1) With the engine/car off and key out of ignition, jump pins 4 & 9 on the OBD connector with a paperclip, length of wire with the ends stripped, etc.
2) Turn your key to the "on" position. Don't start it, but just turn it on.
3) Your SRS light is gonna blink. Pay attention to the pattern! Luckily, the SRS light illuminates for 6s (bulb check), shuts off for 3s, then it starts the main code. After the main code, you get a 2s break to relax your eyes, then the sub-code. I'm not 100% sure on what happens after the 3s pause after the sub code, but it likely goes straight into the main code again.
  • The first set of blinks (after the bulb check) is gonna be the main code. Could either be slow blinks (1.2s between blinks) or super fast blinks (0.1s between blinks)
    • Count each slow blink as 1
    • Count each set of 4 super fast blinks as 10
    • Add them all together, and you get the main code
  • Second set of blinks is gonna be the main code. Remember, you get a 2s break to compose yourself. lol.
    • These are gonna be about 4x as fast as the slow blinks from the main code (0.3s between blinks)
    • Count each blink as 1
    • Add them together for the sub-code.
After you do all that, you should end up with a [main code]-[sub code] pairing. Match it to the list below, fix whatever issue instead of spray and pray with the parts cannon.
Hope this helps your troubleshooting
p.s. I deleted your other thread
Old Nov 10, 2019
noquacks's Avatar
Thanks, Rice!! I will try to pull those codes asap! Will let you know!
Old Nov 10, 2019
noquacks's Avatar
Rice, not sure if Im counting right, but first srs light comes on and stays on for say, 5-6 seconds. Then I get 4 super fast blinks(hard to even keep up/count correctly), then 5 slow blinks, then lastly, slightly faster, 3 blinks. Then srs light stays on permanently. I get 10+5-3 =15 -3. Can you confirm what code I have given this?
Thanks!
Old Nov 10, 2019
Sounds like a 15-3 to me
6-second bulb check
Main Code
4 fast blinks = 10
5 slow blinks = 5
Sub code
3 blinks = 3
15-3 Faulty ODPS sensor
Old Nov 10, 2019
noquacks's Avatar
6-second bulb check
Main Code
4 fast blinks = 10
5 slow blinks = 5
Sub code
3 blinks = 3
Wow- thanks, Rice for the confirmation! You are such a great member/resource here! To reply with advice so quick, and on a weekend!
Now to find out how to replace it- I understand I have to peel off the fabric in back of the pass seat, then pop it off, and pop new one in. Thing there is anything else to do? I hope one doesnt have to program a new one, meaning dealer.
Old Nov 10, 2019
lol I live on this site. I've been around since 2003 and stayed, so they slapped an Admin sticker on my ***. Downtimes at work, it's this and another forum I have open dicking around. I've legit made IRL friends on this site *cough @sdaidoji cough* even though they may live in other countries or across the country.
That is beyond the scope of what I know, bud. No lie, I didn't even know 7thgens had an ODPS sensor in the seats. I replaced my 2002's OEM seats (both driver and passenger seats) with Sparco racing seats and transferred over the seat belt buckles and popped zero codes. Even replaced them with OEM used black buckles to match my black seats.
Old Nov 10, 2019
noquacks's Avatar
No problem, rice. At least you got me this far. I will search around, for this opds fix. Will try to get back to you on this with my progress.
Old Nov 10, 2019
That's all I can ask. Update your progress in this thread in case some poor future soul has the same issue
Good luck!
Old Nov 10, 2019
what do you mean about friend? :P
concerning the main thread problem, sorry, my seats have never leave the car since i bought the car... just replying to the tag rice put on me
Old Nov 12, 2019
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
If you are certain it is 15-3 (dealer can confirm) then the OPDS unit may need to be initialized/callbrated again - unless it is faulty. Did you have a laptop near the passenger's seatback recently, as they can have an effect on the OPDS?
https://www.civicforums.com/forums/3...necessary.html
https://www.autosafety.org/wp-conten.../HondaOPDS.pdf
Old Nov 12, 2019
noquacks's Avatar
YIKES! I studied both those links, especially the 2nd one, and man, looks too complicated- to initialize. Only tech tool I have now is a paper clip. Maybe I should just abandon this. I thought of pulling a unit from an old civic in the local junk yard, only $15. But why bother, if I have to initialize it, whatever that means. Unless a "good used" unit from a junk yard car does not have to be initialized, well, then I will pull one and try it. Do ONLY new ones have to be initialized?Please advise.
Old Nov 13, 2019
NDNV's Avatar
Sorry no personal experience with the OPDS repair/replacement - just what I have read.
If it were my vehicle, I would take it to a dealer as it is a safety component plus I have kids that sit in passenger's seat frequently.
Old Nov 13, 2019
noquacks's Avatar
Thanks, ND. No more kids here. Still, could be a concern. I take it with it "not functional" that means airbag would deploy with a child or an adult. Gonna take a chance on a junkyard part. Low risk. Can always return it. Easy to remove/install. Maybe even no need for programmimg.
Old Nov 13, 2019
Ric Mc's Avatar
Ric Mc is an unknown quantity at this point
Just pull the guage cluster un plug yellow connector in back and no see light will be on quick fix till you resolve issue
Old Nov 14, 2019
BrotatoChip's Avatar
Super Moderator
If the SRS light is on the airbags will not deploy in a collision.
Does your car have side airbags? These are located on the sides of the front seats. I think you only have a OPDS unit with side airbags. Possibly your original replacement came from a car with side airbags and your car does not have them. That's why you got the failure for OPDS. If you don't have side airbags stick the original module in then pull faults from it.
Old Nov 14, 2019
noquacks's Avatar
Bro,
My car does have side air bags. Also, I am the original owner. No one has molested my car. Feedback appreciated.
Old Nov 15, 2019
Super Moderator
Well there goes that idea. Hopefully a replacement module takes care of it.
Old Nov 15, 2019
Totally forgot that some 7thgens came with side airbags. lol
edit: I guess that explains why I never had SRS light issues after switching out to Sparcos
Old Nov 15, 2019
noquacks's Avatar
Right- Not sure if it means anything, but mine is an EX. Maybe all EX's have these side airbags(?). Anyway, people, tomorrow is the big day- going to the yard, hopefully find a sensor with my same part # on it. Pop it in and see. I will get back to you all!!
Old Nov 15, 2019
Nah, mine was an ex without side srs, so there goes that theory. lol
Old Nov 27, 2019
noquacks's Avatar
Finally tried 2 sensors from the junk yard. Both failed. Sheesh. It was a small gamble. Oh well. Gonna patch up the seat cover with orig sensor. I guess my air bags wont work, but who cares. My daily driver doesnt have any.
Thanks to all who tried to help here.
Old Nov 27, 2019
noquacks's Avatar
Brotato, are you saying that with my srs light constantly on NO airbag will deploy, or just that the passenger airbag will not deploy? Also, reminder- I have side airbags. Im orig owner as well. Thanks.
Old Nov 27, 2019
leok99's Avatar
leok99 is an unknown quantity at this point
Give this a try: dry the passenger seat back and reset the OPDS without HDS.
Safe one
Not so safe...
Old Nov 28, 2019
noquacks's Avatar
I will look into this asap, leok. thanks.
Old Nov 28, 2019
Super Moderator
No airbag will deploy if the SRS light is on.
Old Nov 28, 2019
noquacks's Avatar
Thanks, Bro, for confirming. I learned something.
botmark
24
Aug 21, 2019 12:58 PM
cernicalo1
Aug 9, 2016 12:36 PM
Downhill Demon
Jun 3, 2011 09:58 AM
rjones7755
May 28, 2011 01:46 PM
DieMaster
Aug 5, 2008 08:51 PM
