Safety/Security Items - SRS, Keys, Immobilizer, airbags, ABS Post your safety, security questions here! Airbags, Keys (immobilizer)
SRS code 09-02
Old Sep 25, 2019
richcabras's Avatar
richcabras is an unknown quantity at this point
Exclamation SRS code 09-02
Hi just came from the dealership and got my srs diagnosis and hopping that it would be 09-03 due to buckle replacement due to recall but it didn’t turned out to be. They diagnosed with code 09-02 and wanted to charge me $130 pulse repair. I was wondering if anyone has that issue before or know how to fix it any help with be appreciated.Thank you
Old Sep 26, 2019
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
Re: SRS code 09-02
Check for a bad battery and loose alternator bracket bolts causing a poor ground. This code 9-2 could be caused by a bad battery and/or bad charging system.
Old Sep 26, 2019
richcabras's Avatar
Re: SRS code 09-02
I didn't know that can cause that issue with SRS Light I will check today when I get home thank you that you for the feed back I will update.
Thanks
botmark
24
Aug 21, 2019 12:58 PM
BrotatoChip
Aug 31, 2018 01:17 PM
Ricky Rick
Feb 3, 2018 06:01 PM
2k1_Toaster
27
Aug 6, 2012 08:50 PM
DieMaster
Aug 5, 2008 08:51 PM
