Safety/Security Items - SRS, Keys, Immobilizer, airbags, ABS Post your safety, security questions here! Airbags, Keys (immobilizer)
Cold immobilizer causes no start
Old Oct 12, 2022
gothicsunrader's Avatar
gothicsunrader is an unknown quantity at this point
I have a 2002 Honda Civic EX, crank no start when 20F out. It turns out it is the immobilizer. If I heat the key and steering column with a blow dryer or a hot water bottle, it will start. Note: I keep my keys in the car. They freeze too.
Notice on the dash the green key light. In key position II it should come on for a sec then should go out. It it doesn’t go out, that’s what is keeping the car from starting. The fuel pump is being cut out. It’ll crank but not start. Also, flashing green key light is bad.
Old Oct 12, 2022
Re: Cold immobilizer causes no start
try to get a new key. It need to be programmed.
Old Oct 13, 2022
Colin42's Avatar
Does it start fine if the keys aren't kept in the car?
Old Oct 13, 2022
Don’t know and here’s why. I epoxied my one and only chipped key to the column next to the sensor. (I don’t want to pay the price to get spare chipped keys). This way any cut key will work.
This works fine except for now, this first time it’s seen 20F overnight.
Warm up the area and the flashing green light disappears in the II position. And the car starts.
I just offer this as a possible fix when the immobilizer is keeping your car from starting on cold mornings.
Old Oct 13, 2022
Colin42's Avatar
Fair enough, I did a similar thing with my truck. Don't have that issue though. Maybe you could use a small space heater connected to a timer to turn on a few mins before you have to leave.
MJ32
Electronics
Oct 13, 2022 07:25 PM
thumbelina
Jun 12, 2019 08:42 AM
chuyg13
Jun 1, 2014 02:13 AM
bigbduster
Mar 12, 2014 06:01 PM
fyrfytrryn
Feb 3, 2006 10:50 PM
