- Short in plate and tail running lights
- No Start after Clutch replacement
- Ecu problems
- Stereo
- keyless entry not working after successful programming
- Remote start Civic 2004
- Manual Swap "issues"
- Replaced Gauge Cluster, SRS Light Now On
- 2002 Civic - Heater Control Cable 79544-s5d-aoo
- Replacing 2005 EX auto Speedometer, mileage carryover?
- Glow plug indicator light remains on
- My civic 03 sedan doesn’t honk while lock/unlock
- Cruise Control Not Engaging
- Manual throwing codes for a/t?
- Wire harness
- Aftermarket alarm going off
- 2003 civic ex 2dr MICU issue
- EM2 Civic. Maintenance light won't reset
- Instrument cluster
- Gauge cluster works intermittently
- Abbreviation meaning on radio
- 2001 civic ECU location
- Low gas light [solved]
- Minor fender bender disabled Honda Civic 2001 alarm receiver?
- Can you turn off the Auto Lock Feature on 2003 Civic lx
- 02 Civic CoupE OBD2 Port Loose
- ECM swap
- Radio clock
- Gauge cluster help?
- not connecting to scanner
- After Market keyless entry works, but won’t unlock or lock doors
- No Dash Lights after bulb replacement [solved]
- Whats the Stock 6.5 / 6X9 Speaker RMS for a 2003 Honda Civic LX Coupe?
- Replace chip in ECU is for AC? 01 Civic Coupe EX Manual
- 2004 Cruise control quit working & feels like slipping accelerating from stop
- Alarm not working!
- Replace gauge cluster?
- ecu question
- 2002 EX Coupe Intermittent Cruise Issues (w/ headlights)
- Need help bee r limiter
- Driver side lock almost broken - Keyless entry an option?
- Remote won't disarm the alarm
- Speed sensor installation question please [solved]
- Car security system
- Inaccurate Speedometer
- Dimming power
- Should losing gas affect my mpg readout?
- Car will not enter programming mode
- 2004 Civic EX not recognizing key is removed from ignition
- 2001 honda civic conversion to intermittent wiper adjustable
- 2001 honda civic lx 4 door cruise control not working
- How can I diagnose a bouncing Speedometer?
- Car suddenly died on freeway
- Fried my ecm on my 03 ex v-tech
- Horn won’t stop blowing
- Keyless entry
- doors spontaneously locking - 2005 Civic
- 2002 civic EX PCM issue?
- Dumbest question ever
- Honda Civic 2008 instrument cluster
- 2004 Civic VP coupe temperature guage
- Bought a Honda Civic that a mouse got into help
- ECU Fuse wrong amperage
- 2002 civic act’s like it has rev limiter
- Relay pin out diagram does not match
- Digital fuel gauge is reversed ..help
- Parking Brake Light After Cluster Swap
- Cluster mileage correction
- 04 VP Cluster Change PLEASE HELP
- Stereo install fail - don't know why.
- 02 civic Ex sedan Instrument Srs HELP PLZ
- Factory Keyless Entry Not Working
- 2005 Hybrid
- WHAT ECU 2004 civic si automatic?
- Alarm going off when sitting in unlocked car for too long
- 2005 Honda Civic EX Speedo
- Seat Belt light & SRS light issue.
- SRS Light
- Cruise Control light is always on
- What in this sensor?? is this ELD?? found this
- a few problems with 2002 civic lx
- 2003 Civic ignition switch. Used OEM or aftermarket?
- Need help with Key Fob programming
- Cruise Control - no lights, but affects transmission
- Key fob
- Replacing ECM/PCM/ECU
- Where are the grounds?
- Peter
- Mechanic Says I have a bad PCM. im very new to cars need help
- Honda Civc 2005 possible ECM/PCM failure, your opinion please
- Cruise control retro fit
- Possible VTEC wiring issue... Have some questions!
- Obd wiz issues......
- 2003 HCH SRS light won't go away!!!
- 2001 Civic EX Cruise Control Issue
- Gauge Cluster oddity...
- civic hybrid NCNS and an annoying shop.
- 2005 Civic Engine light on, ODB2 Connector
- Horn doesn't sound when I dbl click my fob
- 2003 Civic DX. Getting a p0336 code and associated issues after replacing ECU
- No Crank, No Start
- 2005 civic radio restart
- 03 civic lx limp mode . Loose upper alternator bolt . Fried Ecu? Where do I start?
- dimmer switch bypass
- 2001 ex sedan cruise control issues.
- Reprogram idle RPM
- 2003 honda civic
- 03-05 cluster to 01-02 Problem
- Reprograming Computer
- 2001 Civic LX 4D Manual cruise control not working
- Criuse control does not work
- Fried computers ??
- Remote Lock but No Horn
- ECU Honda civic 2005 Automatic
- 2004 Replace ECU
- Power locks don't work
- 2002 Civic EX: Best quickest least expensive options for computer board?
- Vtec idles high while in neutral
- interchangable ECUs?
- Emissions NOT READY?
- How to Retrieve ECU/PCM from Foot Well?
- Need Help with 2002 honda civic
- cruise control disengages in hot weather
- Please Help ! Speedo not working !
- 2001 Honda Civic ECU ECM problems
- Cruise Control and Speed Sensor
- 01 Coupe: Radio on, but no sound?!?
- Cruise Control Question
- 2004 Civic - Speedometer works only when car warm
- Remotes won't lock doors but unlocks doors
- Messed with radio - now no power to radio, PL
- 2004 civic radio error code
- Cruise Control Issues with 03 civic ex sedan
- Multiplex Control Unit
- cruise control no longer working
- PLEASE help i need to ECU pinout for a 2004 civic ex
- Cruise control not working
- maint. checkup
- Maint. Required Light?
- My ECM is blown!!! What could cause this?? I NEED HELP NOW!!!
- Is there an actual gas gauge FIX???
- Curise Control "Cancel" button sticking in the cold
